blinkers
Old May 15, 2007 | 09:52 AM
skunktruck's Avatar
skunktruck
Unhappy blinkers
Hi all,
What would cause my inside blinkers to not work? I can hear the sound but no worky. They work fine from outside and the inside bulbs are new so not sure. Must be missing somthing...right?
thanks
Old May 15, 2007 | 12:04 PM
Jermafenser's Avatar
Jermafenser
Cluster printed circuit?
Old May 15, 2007 | 01:02 PM
Mil1ion's Avatar
Mil1ion
You obviously mean the indictor lights in the cluster.
Problem can be a couple of things.
wiring from switch.
Printed circuit board
burnt out bulbs
Corrosion on connections for bulb socket not allowing bulb to receive current.
Old May 15, 2007 | 02:29 PM
skunktruck's Avatar
skunktruck
not sure if I have a printed light cluster? bulbs are good.
Old May 15, 2007 | 02:50 PM
Mil1ion's Avatar
Mil1ion
You have a printed circuit on the back of the cluster.
Everything but the odometer/speedometer works off of that.
Corrosion..the white stuff shown here caused by oxidizing copper can cause a bad connection.
Old May 15, 2007 | 09:00 PM
rusty7983's Avatar
rusty7983
my board was bad. i could get one inside blinker to work, and none of the gauge lights. my cluster was in poor shape. i replaced it. 20.00 on ebay. it works good now.
Old May 17, 2007 | 09:56 AM
skunktruck's Avatar
skunktruck
hey thanks, but cant I cheack for volts on the back somewere?
Old May 17, 2007 | 11:40 AM
Mil1ion's Avatar
Mil1ion
sure can ..or use a test light.
Old May 18, 2007 | 09:23 PM
rusty7983's Avatar
rusty7983
check the wire at the plug connector. i think it was light blue with a red stripe.
Old May 18, 2007 | 09:53 PM
Mil1ion's Avatar
Mil1ion
Blue /red stripe is cluster courtesy lighting.......not T/S indicators
rossseger
Nov 3, 2014 02:09 PM
lemasters f100
Feb 15, 2013 12:16 AM
heatherc
Dec 19, 2012 08:59 PM
Rhizome
15
Apr 26, 2012 09:59 AM
texasjammer1
Nov 4, 2011 06:59 AM
