Powerstroked
Old May 14, 2007 | 07:25 PM
XylemXorro's Avatar
XylemXorro
Powerstroked
Anyone know the part number for that bracket the holds the plastic Powerstroke logo on top of the motor? I put the "Powerstroke" on the nuts and broke the studs...
Old May 14, 2007 | 07:48 PM
MAKO314's Avatar
MAKO314
drill out the studs and replace them with some bolts
Old May 14, 2007 | 08:37 PM
RedTaurus94's Avatar
RedTaurus94
MAN! The exact same thing happened to me Saturday when I was changing the fuel filter. That sucker is real rusty for some reason. Must be made by a Chevy part supplier or something. Anyways, I just left the cover off for now. Maybe next Saturday, I'll have a chance to fix it....
Old May 14, 2007 | 08:46 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I have a bracket and the cover im almost sure, do you want me to send it out to you? I think the bracket is still on my truck and if it doesnt attach to anything i can send it out
Old May 14, 2007 | 08:49 PM
RedTaurus94
It attaches. There are at least two, and maybe three bolts/nuts that hold it on. Probably fairly easy to remove with a wrench or two, though. If XylemXorro doesn't need it, I might be interested....
Old May 14, 2007 | 09:31 PM
John311t's Avatar
John311t
Mine has been gone for a long time....
Old May 14, 2007 | 09:50 PM
monsterbaby's Avatar
monsterbaby
I'm with Kris I got tired of removing it any time I wanted to replace the fuel filter and just left the cover off. been thinking of removing the bracket too cause I had those studs sticking up. doesn't serve any useful purpose that I can see except maybe cosmetic and I never liked the looks of plastic on an engine.
Old May 14, 2007 | 10:00 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Yea, and that bracket is rusty too. Mine is holding my current bleed valve setup. All of this will change before too long as that bracket will get cleaned up or removed when I modify the bleed fitting.
Old May 15, 2007 | 04:35 AM
powerstroked162's Avatar
powerstroked162
Tenn- Whats that monstrousity of fittings you call a bleed valve for?
Cowboy Steve
