Sponsored by: Real Truck
Squealing is driving me crazy!
Old May 13, 2007 | 09:20 PM
Blue'87GT's Avatar
Blue'87GT
Guys--I'm trying to figure out where the squealing is coming from with my '03 F250 four door 4x4 with 31K miles. The noise almost sounds like the wheel bearing seal problem I had on my Bronco a while back. It does change sound with speed. It does not stop when I apply the brakes. It does not change tone when I put the truck in neutral while rolling. It comes and goes at times, but has become much more frequent lately. I really cannot tell which end of the truck it is coming from. I always seem to guess wrong!
At first I thought that it was the brakes, but after pulling all of the wheels and checking the brakes, I'm sure they're good. Then I thought that it was possibly the drivers side needle bearing(thought that it was that side), so today I tore it down and lubed the perfect condition bearing just to be sure. I'll do the pass side next weekend when I have time off of work to get it done.
Tonight I had my wife drive it in a large parking lot while I ran along side, and to my surprise, it seems to be coming from the center of the truck, not any of the wheels! I also rode in the bed and came to the same conclusion. Could it be something along the driveline? The sound does seem to be speed sensitive, with it continuing all the way up to 80 mph (max I have gone with it). Any ideas will be of great help to me. This sound is driving me crazy!
Old May 13, 2007 | 09:41 PM
evl150's Avatar
evl150
Could be a dry u joint.
Old May 13, 2007 | 09:46 PM
msgtg's Avatar
msgtg
I agree, either carrier bearings or u-joints! I'd check them before something locks up and causes more damage.
Retired from Hanscom in 99...good luck!
Old May 13, 2007 | 10:47 PM
devon123's Avatar
devon123
I would also check your ujoints as well. They may feel fine and still be tight but I am sure they will be dry. This has happened on my bros 02 2 times now.
Old May 13, 2007 | 11:42 PM
crabhab's Avatar
crabhab
Driveshaft carrier bearing?
Old May 14, 2007 | 09:08 AM
mgf250's Avatar
mgf250
Probably an engine component pulley going bad or just dirty? I rule out a U-Joint because you mentioned that it does not change tone when you go to Neutral.
Old May 14, 2007 | 10:02 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Lock the hubs, and take it for a ride, see if the squeeling is gone.
Old May 14, 2007 | 10:24 AM
Big Orn's Avatar
Big Orn
Krewat is on to something here.
Also - make sure the hub or hubs are not sticking in the locked position. If you have ESOF, that is.
If that's not it - take a look at the carrier bearing as was posted by msgtg - make sure the rubber around it has not failed.
twall_SD250
Aug 19, 2011 08:31 AM
nix4x4
Apr 1, 2010 01:20 AM
twirth
1997 - 2003 F150
Dec 13, 2006 11:29 AM
sa_rains
19
Dec 3, 2005 11:39 PM
Lojack1
1983 - 2012 Ranger & B-Series
Nov 18, 2002 06:47 PM
