So here's the scenario; I've been "restoring" an 85 F150 inline 6. Sometimes it feels like I'm destroying it all over again. Anyway, I just put the catalytic converter part back on. This truck came with a unit that has two converters. I noticed 2 cracks in the back one so I pulled it and welded, then put the unit back. I recently replaced the manifolds and pulled the carb, etc...to do it. Put that back on and plugged everything coming off of it until I figure out how it all gets connected correctly. Guy before me didn't do very good job. So I started the truck, runs great, noticed some exhaust coming out of the manifold, kind of sucks but I can deal with fixing that, noticed some exhaust coming out bottom of the first cat conv, this really sucks. Noticed some sparks, maybe cat conv rubbed against jack, then wammy...FIRE.... Incidentally my wife pulled up at that moment ready to freak. I extinguished fire, calmed her down, then went into shock. What happened? Too much fuel not circulating through the engine and coming out cat conv? Any other ideas? Suggestions?
Thank You
Chris
nevr heard of that much feul just runin threw then startin a fire in the cat.are ya shure mabe a mouse or somthing bilt a nest in there and when ya started it the hot exoust caused it
I have had that happen to me before with an 83 F-100 with a 4.9. Bad carb was overfueling, caused the cat to catch on fire. That was my first time using an extinguisher.
At the base of my manifold there is a part that screws in, kind of looks like a spark plug. It has a wire coming out of it. If that wire went live, touched metal and sparked, it could have burned off old oil from wherever it sat. Does this seem reasonable? Any idea what that part is and where wire should go?
It should go directly from the O2 sensor to a connection in the wiring harness...it not being connected won't do much beyond giving bad readings to the computer, but your engine will run more efficiently if you find the harness connection and hook it back up. The wire is usually fixed to the O2 sensor itself. If it's disconnected on that end you generally need a new sensor.
