shifter problem
Old May 13, 2007 | 12:41 PM
yh731801's Avatar
yh731801
shifter problem
1988 F-150, 4.9, 5 speed. my shifter has all kinds of play in it, up and down, sside to side I cannot find the gears without playing around. dioes any one have a blow up pic of the shifter andle and assembly that goes into the trans?
Old May 13, 2007 | 01:13 PM
flareside_thunder's Avatar
flareside_thunder
Depends on the tranny.I believe(I may be wrong) that Ford ran both the M50 5 speed as well as another one, can't remember which one.Sounds like you'd need synchronizers...I'd go for an entire rebuild though to get it all out the way.Including a new clutch.
Old May 13, 2007 | 01:36 PM
yh731801's Avatar
yh731801
this all haPPENED WHEN I REPLACED THE CLUTCH, A FREIND TOOK YTHE SHIFTER OUT , WHEN I PUT IT BACK TOGETHEER THIS GHAPPENEED , THE BALL SWIVEL SEEMS WORN OR THERE MIGHT BE A PART MISSING
Old May 13, 2007 | 05:53 PM
flareside_thunder
Hmmm, sounds like something didn't seat itself quite right.Although, I've noticed alot of the older fords that have manuals have ALOT of play within the channel for the gears as well as in neutral.
Old May 13, 2007 | 06:39 PM
brown 4x4's Avatar
brown 4x4
It's probably an M5OD. There's a pinch bolt that holds the shifter on, probably not tight enough. Take the boot up and you'll see it. 17mm I believe.
Old May 13, 2007 | 08:58 PM
yh731801's Avatar
yh731801
it's tight
Old May 16, 2007 | 01:10 PM
low92flareside's Avatar
low92flareside
i was thinking the plastic bushing under the shifter cap at the top of the tranny may be the culprit.
Daniel Henao
Apr 11, 2016 07:49 PM
Color sarge
Feb 3, 2016 07:22 PM
F250GH
Feb 15, 2011 06:46 PM
mike_rockwell
Jan 15, 2010 05:52 PM
89frankenford
Dec 1, 2008 12:30 PM
