Access holes?
Old May 13, 2007 | 12:04 PM
Turtlesplatter's Avatar
Turtlesplatter
Access holes?
I'm about to connect a CB antenna to the flat bed of my '05 Screw. Was wondering, before I go through the trouble of removing the seat, if any one knew if there were access holes behind the rear seat that will allow me to snake the antenna wire through the back of the cab?
Thanks!
Old May 13, 2007 | 01:07 PM
kd4crs's Avatar
kd4crs
There are grommets in the wiring channels below the door sill plates that might be better for that purpose.
Old May 14, 2007 | 07:39 AM
rmo1's Avatar
rmo1
Where exactly are you mounting this antenna. You mentioned "flat bed"??
Bob
Old May 14, 2007 | 12:30 PM
Turtlesplatter
Ahhhh...I looked under the truck and found the grommets you were talking about. Those may just work "perfecter" than going behind the seat or (my original plan) going through the firewall by the steering column, all the way under the truck and back up. Hopefully the tips of the antenna cable will be able to fit through the hole.
Bob
Yeah, I managed to alter two stock flat antenna brackets and bolted them (one on each side) under the trims of the rails of the flat bed - near where the stake holes are. I have it so that the antennas mount right between the flatbed and the cab. Looks great and they don't even get in the way of my my tonneau cover.
Once I have everything together, I was thinking of posting a "How-To".
Old May 15, 2007 | 09:38 AM
jcsv99's Avatar
jcsv99
I am very interested in seeing this as well - please post the pics as soon as you can. Also, please show us all where you put the reciever.
xbox73
May 2, 2012 10:42 PM
xpauliber
May 22, 2011 08:47 PM
awq134
2009 - 2014 F150
May 10, 2010 09:40 PM
Bob7211
Jan 14, 2006 03:19 PM
Johnnyboy04
2004 - 2008 F150
Dec 8, 2004 08:37 AM
