Antenna Loose
Old Sep 20, 2010 | 07:46 PM
xpauliber's Avatar
xpauliber
Antenna Loose
The antenna is loose on my 78 F150. How do you tighten it? I don't see any access holes on the cowl or anything.
Old Sep 20, 2010 | 08:08 PM
Witty73's Avatar
Witty73
You will need to pop the stainless steel trim cover off the top side of the mount. Gently pry on it with a small flat screw driver and you should be able to pop it off. Underneath you will find four phillips head screws you should be able to tighten.
Old May 22, 2011 | 08:47 PM
cigarxtc's Avatar
cigarxtc
Wow. That is so simple. I have been watching my antenna floppin in the wind the last few months and got frustrated that i couldnt find access to it from in the cab or wheel well. The only thing i did differently was to flip the top plate upside down, as it was worn on one side and did not hold the antenna tight as i bottomed the screws out. Now it's holding great and the stainless trim piece fit just fine on top, even with the screw plate installed upside down. Gotta love the quick easy fixes! Thanks for the info!!!!
slinginsaws
Jul 18, 2014 02:10 PM
rikosintie
Jul 30, 2004 07:58 AM
Cobra-Master
Apr 4, 2004 07:54 PM
philrush
Sep 12, 2003 03:07 AM
bobward737
May 14, 2002 06:08 PM
