94 302- 351
is there any way to find out the ohm resistance for each? or the pressure rating?
Will they interchange? will they fit ? are the wholes the same size?
we will know tomarrow?
I PULLED A SET OUT OF THE 351 W / 90 LARIAT... THEY ARE ORANGE! ARE THEY RATED AT 19LBS / HR?
WHAT IS THE RATING FOR THE OTHERS? WHAT COLOR ARE THEY?
THE BRONCO (89')_ WAS EQUIPPED WITH THE FRAME MOUNTED HIGH PRESSURE FUEL PUMP.
AND ACCORDING TO GP SORENSEN AUTO PARTS THE 89 / 351w HAS THE SAME INJECTOR AS THE 7.5 L?
IN 90,91 ETC THE INJECTOR CHANGED TO THE SAME ONE FOR THE 302 /OR 351...
This was also the year they stopped the frame mounted external pump(which i believe is used jointly with the intank fpin 89)
Timing good,plugs good, the engine ran in the Bronco prior to removal. And also now so long as i supply fuel to the eng manually.
Are the other injectors higher pressure injectors for 89? w /dual pumps?
