Seal Kit
Old May 12, 2007 | 07:07 PM
bigsnow's Avatar
bigsnow
Seal Kit
Where can I find a seal kit for my power assist? It's a 76 f-250 4x4. Thanks
Old May 12, 2007 | 07:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7AZ-3E501-A .. Seal Kit-Input Shaft
F3AZ-3E502-A .. Seal Kit-Sector Shaft
Ford, NAPA...everyone carries them, as they fit most of the 1967-80's trucks and Ford passenger cars from 1965 thru the 1980's.
These steering gear boxes aren't known for reliability. You might be better off getting a rebuilt unit. You will need a pickle fork (Pitman arm puller) to remove the Pitman arm.
Old May 12, 2007 | 07:58 PM
bigsnow's Avatar
bigsnow
Thanks for the help. Those are the part numbers I would ask for at Napa? Thanks
Old May 12, 2007 | 08:10 PM
prrcatenary's Avatar
prrcatenary
Doesn't the '76 F-250 4x4 use power assist, not the power steering gearbox? He did ask for the power assist seals. The "everyone carries them" seal kit is for the Ford integral power steering geabox is it not (up to the '80's).
Old May 12, 2007 | 08:14 PM
NumberDummy
He didn't make it clear if he wanted steering gear box seals, or ram and control valve seals.
So much has been swapped around on these old trucks, who knows what ppl want unless they are SPECIFIC in their requests. I'm NOT a mindreader.
OP..I listed steering gear box seals for a power steering integral Bendix gearbox...DISREGARD if you don't have this setup.
Which seal kits? Ram and/or Control Valve? The CV has a ball and stud kit (3A533), and two seal kits (3A674 & 3A650), the Ram has a seal kit (3A764) and a bushing mount kit (3C590).
Old May 12, 2007 | 10:08 PM
bigsnow's Avatar
bigsnow
It's the ram and control valve I was trying to find kits for...
Old May 12, 2007 | 10:09 PM
Mil1ion's Avatar
Mil1ion
Is this for a garrison box ?
or bendix box
Old May 13, 2007 | 11:17 PM
bigsnow's Avatar
bigsnow
It looks to be a Bendix. When I google those part numbers that NumberDummy gave me, they come up parts for Mercury, T-Birds, Rancheros and others. Are those kits interchangeable with the trucks or are there more to the part numbers? Thanks
Old May 13, 2007 | 11:37 PM
Mil1ion's Avatar
Mil1ion
Bill gave you integral steering box seal numbers.
Have you considered the swap to integral power steering ?
There is one user here who wrote a complete article on the power assist and posted it in this forum.
I can't remember his name but it was in about September 2006.
If I recall his user name I'll post back here.
Old May 14, 2007 | 12:32 AM
bigsnow's Avatar
bigsnow
I would like to try to find the seal/bushing kits for everything first. I do have the steering boxes from a 79 f100 2wd and a 73f cant remember what series 4wd. Any of those work? Thanks
Old May 14, 2007 | 03:12 PM
Mil1ion's Avatar
Mil1ion
https://www.ford-trucks.com/article/...r_Highboy.html
Old May 14, 2007 | 11:11 PM
bigsnow's Avatar
bigsnow
classicautopartsgroup.com has the control valve kits
73-79fordtrucks.com has the bushing kits
bigcrunch
Large Truck
19
Aug 1, 2020 04:20 PM
wakeupluis
Feb 23, 2015 08:40 PM
suzbandit987
1983 - 2012 Ranger & B-Series
Oct 29, 2011 06:42 PM
tweakingit
Oct 23, 2003 07:16 AM
