I had a 78 GMC Brigadere ( yes I know) with an almost identical ram & sent for a rebuilt exchange to Chicago power steering co. 312-842-3083 it worked fine with no leaks.
If you go by Ford part numbers you get a obsolete which is B/S go to either Cat or
New Holland who does cylinders or a hydraulic shop in your area. Far as I know Ford
did not make those they were vender bought. When I did mine a 1954 F900 the local
shop had a big fat book with every kind of piston and seal dimension on the planet. sam
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
----------------------------------------------------------------- C8TZ-3A533-A .. Ball Stud Repair Kit / Obsolete
GREEN SALES CO. has 9.
P/S Cylinder is D1TZ-3A540-A .. The repair kit and ball stud dust cover are listed above. This is not the spindle connecting rod seal, that number is C7TZ-3332-G
