Tach Installation - Coil Ground?
Old May 12, 2007 | 09:41 AM
Americanmadeford's Avatar
Americanmadeford
Alright, Im trying to install an aftermarket tach. I did a search of the forum and got 100 different threads saying "connect the green wire to the negative side of the coil". What is this though? My coil has 3 different wires. Which one is negative?
THanks
85 302 EFI
Old May 12, 2007 | 11:38 AM
Franklin2's Avatar
Franklin2
If you have the big horseshoe connector, it should say "tach" on the correct wire. The negative will also be darkgreen/yellow, not the red/green.
Old May 14, 2007 | 01:04 AM
jimbo beam's Avatar
jimbo beam
on my 86 it had a horseshoe type connector like franklin 2 said, it was a green wire. there was 2 other wires in a connector together, the negative was all by its self out in front. I popped the connector off. i then wrapped the frayed end of the tach wire around the negative on the coil, i popped the negative connector back over the wire. it works fine.
Old May 14, 2007 | 05:54 PM
Americanmadeford
The green one it was. Thank yall!
Skoiv
May 16, 2011 11:34 AM
Dads 66
Jan 1, 2005 08:53 AM
Dads 66
Jan 1, 2005 06:46 AM
oft
Aug 7, 2002 02:50 PM
Darren
1983 - 2012 Ranger & B-Series
Mar 20, 2000 02:02 PM
