400 V8
Old May 12, 2007 | 10:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by RaulLopez
I have a 400 V-8 that is the original. Not according to the VIN you don't.
I decoded your VIN in another thread...the 4th digit is an H which is a 351M, not a 400. If it was a 400, the 4th digit would be an S.
Old May 12, 2007 | 11:01 PM
trinogt's Avatar
trinogt
Rod length is the same between 351M and 400.
Only the crank throw and pistons are different.
(taller pistons on the 351 to make up for the shorter stroke)
Old May 17, 2007 | 03:38 PM
Ford400Man's Avatar
Ford400Man
The engine in my truck,, a 400, was all rusty from sitting for a short time,,8 months! But a little heat from driving it, and a power wash to get the mud from the occasional romps in the pit cleaned it off nicely. Now, instead of having flaky rust chips, it looks like normal surface corrosion which is easy to get rid of with a good wire brush/ wheel!
TIP:
For a little different look, don't just use ONE color. I started with a silver base on my intake and heads, then lightly dusted with a red, and finally dusted with a Ford blue. Came out rather nice if you ask me!
Just a thought though,,,
larryejoh
1966 - 1977 Early Broncos
May 2, 2008 02:28 PM
raymond338
Nov 7, 2004 06:53 AM
V8FordMan400
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jan 9, 2004 07:32 PM
AV8R
1983 - 2012 Ranger & B-Series
18
Nov 5, 2003 11:41 PM
BlueOvalRage
Mar 15, 2002 12:56 AM
