Dipstick
Old May 11, 2007 | 02:18 PM
RaulLopez's Avatar
RaulLopez
Dipstick
The dipstick on my truck is a bugger to get in or out... I have to fight it either way. Could this affect the reading it gives me? Any reason why it would be so difficult to move? Putting it in the last 2 inches is the worst. Should I get a new one? And if so do i just go get one from a junkyard or can you buy new ones?
Old May 11, 2007 | 03:07 PM
bigperm2's Avatar
bigperm2
Is it the dipstick, or the tube (does the dipstick appear to be damaged?) I would think you can find a used tube, dipstick, or both. Just be sure that it is reading correctly when you are done.
Old May 11, 2007 | 03:31 PM
RaulLopez's Avatar
RaulLopez
well the dipstick is a little bent but i'll check the tube
Old May 12, 2007 | 08:59 AM
prrcatenary's Avatar
prrcatenary
Perhaps someone put in a dipstick that's too long and it's hitting the bottom of the oil pan? You mentioned in a previous thread that it had 2 quarts too many when you got it? Could give you false measurements.
Old May 12, 2007 | 09:12 AM
RaulLopez's Avatar
RaulLopez
well when i changed it I had 2 gallons of oil come out of it... thats 2quarts to much right?
Old May 12, 2007 | 09:28 AM
Broken40's Avatar
Broken40
Also keep in mind that a 2wd dipstick and a 4wd dipstick are different in length and you may have the wrong one and don't know it.
Old May 12, 2007 | 09:47 AM
RaulLopez's Avatar
RaulLopez
is there a way to check it?
Old May 12, 2007 | 09:51 AM
bigperm2's Avatar
bigperm2
Measure it, and post the length, someone will be able to let you know if its the right one. If you have a part #, post it and someone here should be able to check it out for you.
Old May 12, 2007 | 09:58 AM
RaulLopez's Avatar
RaulLopez
28 inches from the top of the ring to the tip. and the number i see on it is D7TE-6750BA FORD B
Old May 12, 2007 | 10:03 AM
RaulLopez's Avatar
RaulLopez
Well problem figured out... after i measured the stick i was fighting the stick back in and noticed a dent half way down the tube. felt it and its pretty banged up there.... so if i go take one off of a junkyard, it needs to be off the same sized engine and a 4WD? do they just unscrew?
Old May 12, 2007 | 10:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7TE-6750-BA = D7TZ-6750-A .. Dipstick ~ Fits 1977/79 351M/400 4WD.
It's the correct one.
Depending on where the dent in the tube is, you may be able to use a hammer and lightly tap a wooden dowel down the inside of the tube to remove the dent.
Old May 12, 2007 | 10:12 AM
arctic y block's Avatar
arctic y block
Take a pair of round jawed pliers and try and squeeze the dent back to round. If you are careful this can work. Ya don't have to get it perfect. And it is easier than replacing the tube.
Old May 12, 2007 | 07:01 PM
Broken40's Avatar
Broken40
Not only is it easier to do that but, man it is a pain in the rectal area to put the dipstick tube back in, it doesnt just screw in like you would think, it actually slips right in but it has to be resealed and it sucks trying to make it seal. I would try to squeeze the dent out before replacing it.
Old May 12, 2007 | 09:48 PM
NumberDummy
At the bottom of the dipstick tube is a rubber "O" ring. That's what seals the dipstick.
87034-S94 .. "O" Ring ~ Dipstick Tube
Fits: Nearly every tube from the early 1960's up.
Available from our FTE Ford sponsors: $1.04 list / FTE member net .62
Old Sep 26, 2009 | 01:35 PM
bonesbmx's Avatar
bonesbmx
angling your dipstick tube
i need to slightly move the angle of the tube. i want to slightly move it so its more angled toward the front rather then pointing up. (not relocating) how would you suggest doing this? my manual says nothing about the dipstick tube.
