hello everybody I think I brought this topic up a while ago my fuel light stays on all the time my gas tank works properly it reads correctly when its full or empty is there a fix for this problem.
Some of them had a fuel economy light hooked up to a vacuum switch that turned the light on when your foot got heavy. I personally have never seen a fuel level light but they may have had them outside of the USA.
Check with NumberDummy to see if he has a picture of the part. Dennis/Mil1ion may have a wiring diagram that shows the switch also.
I do not know if it is screwed directly into the manifold then connected with one wire or if it is connected by a vacuum hose and wired with two wires.
At least if you can find a wiring diagram you can disconnect the wire to turn the light off. Other than that you could pull the bulb.
I have one of the gage clusters with a fuel economy light but I have never seen one hooked up.
