A/C acting up, troubleshooting help needed
Old May 10, 2007 | 10:21 AM
lspall's Avatar
lspall
The a/c works fine when the outside temp is below about 95 degrees, above that, it takes awhile for it to start blowing even somewhat cool air. I had the system recharged about a year ago, and it did the same thing last summer after being recharged, any thoughts?
Old May 11, 2007 | 07:48 AM
al52269's Avatar
al52269
Did they find any leak on last recharge?
I know they have a liquid for checking for leaks.
From what I understand you have this liquid put in your a/c system.
And if you have any leaks you will know because the liquid is color.
I can’t remember what its call...
Old May 11, 2007 | 02:21 PM
toolmaan's Avatar
toolmaan
How is the fan clutch, does it work ok? You said you had it recharged why is that? If it had to be recharged than there must of been a leak somewhere. Hopefully they put tracer dye in the system so they can possibly use a black light to track down the leak. Fords are famous for compressor shaft seals going bad. Make sure who ever is working on it knows what they are doing. Don't let anyone put stop leak or anything like that in your AC system.
Old May 11, 2007 | 06:38 PM
stone007's Avatar
stone007
Make sure your condenser is clean (the coil in front of the radiator). Could be a bad clutch fan but sounds more like you have a leak like toolmaan said probably the shaft seal on the compressor.
MurderMode
Jun 30, 2012 10:05 AM
john72ss
1983 - 2012 Ranger & B-Series
17
Jun 21, 2011 02:33 AM
brian_06328
Jun 8, 2010 07:53 PM
Aerocook
Aerostar
25
Jun 13, 2006 01:48 PM
blessteve
Aug 25, 2005 07:54 AM
