900 dollars to recharge a/c???
The price or R12 has reached and passed its peak. Now, the only people desiring to use it are restoration fanatics{not meant in any sort of negative way}. Very few original R12 systems are on the road.
I would think that there must be more than an evacuate and re-charge at the $900 mark. Any parts being replaced? I would expect that a lot of the original A/C parts are now made of unobtainium, and very hard to find in good shape.
Last time, years ago when it was still very popular, I think I paid $30 a # for R12, and it should be less now.
tom
tom
on
Are they repairing a leaking part and putting a warranty on it??
I know the juice is expensive, but it doesn't take that long to weigh the charge in and say good luck.
Actually (I do refrigeration work), I have heard the price has started to come down due to the lack of demand.
I would take a chance on a R134a retrofit. At least call around. Someone might know someone who can help you out.
here is a couple of links for you to check out , and i have seen some conversions that worked pretty good and did not have all that much invested ! whoever told you $1500.00 i would run as fast as you can as he is playing you , unless there is some serious parts that are broken !
R12 to R134 refrigerant conversion? - Ford F150 Forum - Community of Ford Truck Fans
https://www.ford-trucks.com/forums/2...-to-r134a.html
we tried a 134 conversion in a dadge van, was a total waste of time and they went back and put the r12 in it. I paid a couple of years back around $600 but it was a new comressor and the works. If you go the 134 route just have the total sytem done new evap, compressor etc as the 134 supposedly requires 2x the capacity as r12. That is why they said my dodge didnt work right and the cost to upgrade was to be out of sight.
The real limiting thing in most conversions is the condenser. If your system was marginal in condenser capacity when using R12, it will be a little more marginal using R134a.
If you looked at the conversion 'kits' that were sold by the OEMs back when, you'll see that they likely specified installing a parallel flow condenser in place of serpentine, or specified add on sealing/ducting to make sure there was more flow of air past the condenser.
In most cases you can get adequate performance from a converted system. Places that have a pretty good heat load were more problematic. Places such as the Pacific Northwest were handled pretty well. For the trucks, with a RWD setup, a fan clutch and duct were pretty much mandated. The edges around the radiator and condenser would be sealed to insure the air flowed through them, rather than around.
CJ06 hits most of the points for a changeover pretty well. Orifice tube changes were pretty model dependent, with some doing ok with the original, and others seeming to need a change to get adequate performance.
Do the accumulator- receiver/dryer change, flush the condenser and evaporator, and any hoses that do not have mufflers or cans of any kind, flush the compressor, evacuate, and then charge to 80-85% of the R12 specified with R134a. The amount of charge is critical, and care should be taken to watch temps as the last ~5% is added.
tom
tom
try this, Enviro-Safe Refrigerants
or
DuracoolŽ.com 2004 - DuracoolŽ is The Recognized Leader In Hydrocarbon Refrigerant Technology
that way you won't have to convert your system.
cc
or
cc
