How can I tell the age of a truck. the serial number is F50DoE43J94 130J F500 09E F Axel 51 1500# 155 3800 rpm 7179 The radiator leaks and the clutch needs to be bled. It has a rear dif. lock. How old is it and how where can I get parts or estimate its value?
How can I tell the age of a truck. the serial number is F50DoE43 J 94 130J F500 09E F Axel 51 1500# 155 3800 rpm 7179 The radiator leaks and the clutch needs to be bled. It has a rear dif. lock. How old is it and how where can I get parts or estimate its value?
Welcome to FTE
The VIN you typed has two incorrect digits. The 5th digit can't be o
There is no J between 43 and 94.
It's prolly a 1969 F500 with a 330 Heavy Duty engine
I can decode everything you typed once you correct those digits.
Hi checked the information. The club told me it is a 1950 truck that was used to pull house trailers (Trailer Homes?). I found various dates 1960 (owners manuel) and 1965.
The serial number in the glove compartment is F50D0E43094 WB130 Color J Model F500 Date 09E Trans F axle 51 max GVW 15000 RPM 3800 DSO 7179
