carrier compatibility
Old Nov 2, 2015 | 03:24 PM
j66b's Avatar
j66b
Anyone know if I can take a ford 9in carrier from a 66 f100 and put it in an 81 F100 9in? Both trucks are 2wd. Thanks, j66b
Old Nov 2, 2015 | 04:23 PM
Old Hickory's Avatar
Old Hickory
You would have to verify the axel spline to be sure. It will bolt in but also look where
the grease fill fitting is. some have it on the housing and some have it on the carrier.
Old Nov 2, 2015 | 07:51 PM
Franklin2's Avatar
Franklin2
I bet the older one is a 28 spline. Most of these trucks are 31 spline. You can change the spider gears to fit the axles, but the 31 spline axle has a larger diameter and won't fit through the hole in the 28 spline carrier. You can take it to a machine shop and let them open it up.
Rusty_S
Sep 25, 2015 10:42 PM
overlandexpress
13
Jun 22, 2011 12:07 PM
fordxxx
Feb 11, 2006 07:02 PM
joeymac64
Mar 9, 2005 12:43 AM
hound1234
Mar 16, 2004 06:48 PM
