Heaviest Load EVER!
Old May 7, 2007 | 01:19 PM
PROSTOCK's Avatar
PROSTOCK
Heaviest Load EVER!
I made a trip to the dump in my '65 F-250. I knew it was gonna be big, but when I pulled onto the scales and saw 7600lbs, I about crapped. I ended up netting 2800 lbs of "stuff". Not bad, 1.4 tons in a 3/4 ton truck! (still had a couple of inches of spring travel left, steering was a little light )
Old May 7, 2007 | 04:58 PM
jowilker's Avatar
jowilker
I have had nearly twice that on my F100 several times. When you get 6-7,000 lbs on there you then will have something to talk about. IMHO
John
Old May 8, 2007 | 08:47 PM
nick65f100's Avatar
nick65f100
6-7,000 pounds are you serious, that is truly impressive? Ive had about 2800 lbs. in mine and I could have swore that 2805 would have lifted the front tires off the ground. It is amazing how much these old trucks can haul.
Old May 8, 2007 | 09:00 PM
gangstakr's Avatar
gangstakr
Go ahead and brag PROSTOCK It was in your truck, any time you can haul so much weight that you almost crap your pants it's worth bragging about. I've had just over a ton in my 1/2 ton, enough to make me lose my boxers for a while dug'em out later but stayed puckered for a while makes you just want to kiss the old girl.
That's why after all my work was done (heavy hauling) with my truck I rewarded her with a makeover, what you see in my gallery was from love for the old gal. She might not haul A%$ but she sure hauled.
Old May 9, 2007 | 08:36 AM
PROSTOCK's Avatar
PROSTOCK
I can't imagine that much weight on non-load range E tires. Most "car" tires are only good for ~1500-1700 lbs each.
Old May 9, 2007 | 01:59 PM
59INA40's Avatar
59INA40
It does not matter how much you have over loaded your truck. Someone will have hauled something heavier. I'm not sure that hauling excessive loads is really something to brag about. I've done it but I won't admit to it. Steve
Old May 10, 2007 | 09:36 PM
Grigg's Avatar
Grigg
There comes a time when stuff breaks. Yesterday I had about 23,000lb combined truck, trailer, and load.
The truck is a 61 f350 with larger axles, a Detroit Diesel 6V53TT, and a 10 speed roadranger.
A long story short, steep hill, lots of weight over rear axle, heavy trailer, 2,500 rpm, first gear, and driveshaft is seen laying in driveway as truck drifts backwards.
Twisted tube off at rear yoke. The tube was 3.5" and thinner wall than recommended for the power I have, I knew it, so the failure was not unexpected. Better at home than on the road.
Tomorrow I go to have a heavier driveshaft made, and I probably won't try such a steep hill with that much weight again.
Old May 11, 2007 | 08:08 AM
brider's Avatar
brider
Empty weight of F250 = 4800#?!?!
Grigg-
Did you save that twisted driveshaft for a cool conversation piece or object d'art? I've seen a similar one sitting on the front desk at a driveshaft shop, and it's an AWESOME static display of incredible torque.
Anyway, Prostock: 7,600 lbs is probably over the GVWR of your truck, right? My '66 F250 has a 7,000 lb GVWR, and last week I picked up a yard of gravel, at about 2,900 +/- lb a yard. Driving it and looking at the spring sag, I've DEFINITELY had a higher load in it, which makes me suspect the scale weight(s) you report. Your numbers would suggest a 4,800 lb empty weight of the truck; is that correct? Is it really that heavy empty? If so, the heavier load(s) that I have previously carried SCARE me now...
Not try to challenge you or anybody, just trying to verify the empty weight. I can't believe it's that high.
Old May 11, 2007 | 08:32 AM
PROSTOCK's Avatar
PROSTOCK
Originally Posted by brider
Grigg-
Yes it is, and I think there have been several threads on weights of these trucks and pretty much that's what they are. In fact, I've been to the dump several times and it used to weigh in about 4600 and change. Then I changed the rear diff out to a DANA 61 from a 1-ton(huge 12 x 3" drums) and that added about 150 lbs to her.
Keep in mind these trucks are made out of real steel, not the light gauge stuff they use today.
Old May 11, 2007 | 09:06 AM
brider's Avatar
brider
AMAZING. That explains why my truck handled fairly well with 2900 lbs in it, it was at or near it's GVWR, which the chassis and brakes were designed for. When I had it overloaded, the handling and brakes were SCARY, won't do that again!
puttster
1983 - 2012 Ranger & B-Series
Mar 11, 2015 11:08 PM
abyars111
All Things Towing
17
Jan 24, 2015 09:51 AM
vortec 1
Oct 31, 2014 03:13 PM
ewsanchez
2004 - 2008 F150
Apr 26, 2014 06:39 AM
crazy96863
15
Mar 6, 2012 02:31 AM
