1978 - 1996 Big Bronco
bigger tires??
Old Jan 29, 2001 | 01:19 PM
chad87's Avatar
chad87
bigger tires??
I have a '87 bronco with 235/75/15 on it now. I want to get bigger All Terrain tires. What sizes can I get without changing anything else on it?
Old Jan 29, 2001 | 06:02 PM
christop43's Avatar
christop43
bigger tires??
Some Broncos came stock with 31x15.50's on them. Those fit fine without any problems. I have heard of people running 33's, but those probally rub under tight turns and suspension flex
Old Jan 29, 2001 | 06:08 PM
jopey's Avatar
jopey
bigger tires??
31x10.50's are common.
I have the 32x11.50 bfg m/t's and love them. they do how ever rub the radius rods when turning full. other that they have cleared the fenders for most of my wheeling so far
If it is still running. you didn't try hard enuf!
Old Jan 31, 2001 | 12:18 AM
fourxforddave's Avatar
fourxforddave
bigger tires??
I have a 92 and i put BFG mudder 32x11.5 on factory rims and they rubbed the radius arm at full turn. I added a 4" procomp lift and they still rubbed. I think the only way to get away from it is with offset rims.
Old Jan 31, 2001 | 10:59 AM
hillbillyk's Avatar
hillbillyk
bigger tires??
31 10.5 15 fit good, just rub the radius arm a little at full turn.
Old Feb 1, 2001 | 06:39 AM
AlM's Avatar
AlM
bigger tires??
[font size="1" color="#FF0000"]LAST EDITED ON 01-Feb-01 AT 07:47 AM (EST)[/font][p]Since your 87 may have some spring sag, 31's as the guys here have suggested are prob your best bet...check out each potential tire's actual diameter w/right air pressure to be sure..tread width makes a differece too!
I have 32x11.50's on my 96, had to adj the driver's side bumper up a bit and trim off the plastic air dam there a bit.
here is a neat www site for big bronco faq's..has tire info sizes too.
http://www.off-road.com/ford/bigbroncos/bbfaq.html#2
Also, the Goodyear tire site shows their tire sizes for a comparison; here is the GY site for the MTR brand with sizes:
http://www.goodyear.com/us/tires/tirecatalog/WRLMTRSize.html
And some 31's and most 32's will change your odometer and speedo readings..about 6 mph. I guess you have a diy speedo gear change and you can get those little gears (color coded) from Ford or local tranny/tire/off road places. I believe you need to know your 235's actual tire diameter before you throw them out so the dealer will know which gear to give you for the tire size and brand you choose to use. Mine need a comp adjustmt at fore for $100.00..e4od shifts better now with the adjustment (96 bronco)Good luck!
Old Feb 13, 2001 | 11:56 PM
lucobb's Avatar
lucobb
bigger tires??
I have an 86 bronco and i just put 33x10.50 from BFG T/A. They are an expsive tire but are nice. They just rub the radius arm at full turn. i just put a 3" body lift so i dont know what they do at full flex.
Old Feb 14, 2001 | 10:05 AM
hipropos's Avatar
hipropos
bigger tires??
hopefully by now you have new tires onner. but I have a 95 EB 302 with stock rims no lift. changed out 235 15 75 to a 265 15 75. sized them up to the 31 10s and there about the same hight and width. saved about 20 a tire. got new tires thanks to firestone. so it only cost me for 4 new tires 40$ to upgrade in size.
Old Feb 14, 2001 | 02:43 PM
soundbeaches's Avatar
soundbeaches
bigger tires??
Hope this helps some:
Years
Lift
Max Tire
92-96* 0" 31"
2" 32"
4" 33"
6" 35"
87-91 0" 32"
2" 33"
4" 35"
6" 36"
80-86 0" 32"
2" 33"
3" 35"
78-79 0" 33"
2" 33"
*92 to 96 Broncos may fit the same combinations as 87 to 91 Broncos if the front bumper is moved forward or trimmed
Old Feb 14, 2001 | 08:11 PM
AlM's Avatar
AlM
bigger tires??
Has anyone with 33's or larger diameter changed your gears?
and have you seen this chart?
http://www.4x4-today.com/docs/projects/pj3_gtchart.htm
Old Feb 22, 2001 | 09:44 PM
ole_blue's Avatar
ole_blue
bigger tires??
I had a 1991 bronco and with standard off set 15X10 wheel i ran 33x12.5 BFG mud ta's with out any rubbing at full turn I did have alil rubbing on the chrome fender trim but nothing a dremmel could'nt take care of
Old Feb 23, 2001 | 01:56 AM
secondstar's Avatar
secondstar
bigger tires??
Ran 31's with no problems. Now running 33's on my '78 Bronco with no lift and they hardly rub at all.
Old Feb 23, 2001 | 06:06 AM
AlM's Avatar
AlM
bigger tires??
Azuretruck
Aug 7, 2016 09:53 AM
donovan
6.7L Power Stroke Diesel
Mar 11, 2016 03:59 PM
Sam Martin
Nov 17, 2015 07:00 PM
brussell
16
May 24, 2003 08:50 PM
