My '78 Bronco sags at the rear. I think this is typical for a 22 year old machine. What are some of the ways to correct this. Can I just put a set of lift blocks in???
SNIP
You could but, lift blocks tend to cause axle wrap and that is very hard on the whole drive train. Better to replace or re-arch your current spring pack, possible adding a full length leaf
Erik Marquez
bronco78@alaska.com
http://www.home.gci.net/~bronco78
Home of the BB decal
I have a '78 Bronco also and i put the bottom add-a-leaf off a '78 f-150 long box. set it just a little high in the rear. I WAS LUCKY enough too get the leafs of a old truck my brother had. Hope to help. ROB
