Code Help Please
Old May 7, 2007 | 04:05 PM
mattpowerstroker's Avatar
mattpowerstroker
Code Help Please
my superduty had the ses light come on today but was on for maybe a minute. So when i got home i pulled these code off of it and not quite sure of what they mean the truck didnt seem to loose power but then again it has seemed alittle slugish since they rebuit my trans so here are the codes po472,po238,po475&po603 it does have the predator program and guages exhaust just a straight pipe i hope u guys can help
Old May 7, 2007 | 04:16 PM
bdrummonds's Avatar
bdrummonds
look here for these codes http://guzzle.rbmicro.com/dtc1.html
472 and 475 are ebp sensor codes( your ebp tube is probably clogged)
238 is turbo high input( could be set from above or could be the Predator)
and 603 is a KAM(keep alive Memory) have you disconnected your batts latley?
Old May 7, 2007 | 04:39 PM
mattpowerstroker
they could off disconnected my batteries for the trans rebuild so the ebp is in the front of the moter not the one back by the turbo i alvest get those confused could that be why it does feel a tad sluggish
Old May 7, 2007 | 04:43 PM
Benny2002's Avatar
Benny2002
Ive heard that most chips of all kinds leave the 0603 code when installed, or programmed. If you program it back to stock then check for codes you might get a better idea of whats wrong.
Old May 7, 2007 | 05:34 PM
mattpowerstroker
what is the way you would go about ondoing the ebp tube since i know mine has never been off
Old May 7, 2007 | 06:02 PM
rbaker6336's Avatar
rbaker6336
I get 0475 code from my hypertec program,no matter what I can't get it to go away with the program in it anymore
it don't seem to hurt anything been there for a couple years and truck runs and pulls good
Old May 7, 2007 | 07:23 PM
Benny2002's Avatar
Benny2002
there are couplers on both ends of it, one on the exhaust manifold, one under the sensor. PB or liquid wrench the crap out of them and carefully try to loosen them. If they wont come undone you can remove the sensor and run some heavy gauge weed eater line through it and ream it out. Then maybe replace the sensor, if it needs it. Mines an 02 just turned 100 and i dont think mine was ever cleaned but it was blocked off right under the sensor, got maybe 1-2 mpg back. but other than that it think it mostly controls the fuel mixture. I know it has a default setting in the PCM but having it function properly would probably lose the code.
Old May 7, 2007 | 07:25 PM
bdrummonds's Avatar
bdrummonds
look here https://www.ford-trucks.com/forums/5...-no-power.html
for EBP directions
EDIT: I see Benny beat me to it.
Old May 7, 2007 | 07:34 PM
guzzle92's Avatar
guzzle92
Well, I have a new one: http://guzzle.rbmicro.com/ebps.html
Old May 7, 2007 | 07:40 PM
Benny2002's Avatar
Benny2002
guzzle where did the gear bearing part come in, did i miss something?
Old May 7, 2007 | 07:48 PM
guzzle92's Avatar
guzzle92
HA!... Caught me... Just some code left over from a template. Thanks for catching that.... I think it's cleaned up now?????
Old May 7, 2007 | 07:53 PM
Benny2002's Avatar
Benny2002
lol, no prob. Love your stuff btw, your maintnence page is bookmarked
Old May 7, 2007 | 08:23 PM
mattpowerstroker
can i unplug it or would it make the problem worse i have read the thread about it being bad to unplug it but i have also heard of guys having there done away altogether
Old May 7, 2007 | 08:31 PM
Benny2002's Avatar
Benny2002
From what ive read i would leave it alone and make sure it works
