Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Driver side mirror replacement
Old May 6, 2007 | 09:05 PM
V X's Avatar
V X
Some nimrod hit my mirror and either didn't know it or, since they also left a gash on the front edge of the fender just behind the bumper, decided they were special and didn't leave a note.(I'm shocked)
Is it difficult to replace said reflecting unit? It is powered but not heated.
Thanks all.
V X
Old May 8, 2007 | 05:03 PM
V X's Avatar
V X
Anyone?
V X
Old May 11, 2007 | 04:55 PM
V X's Avatar
V X
OK. This is how it went after $250 for said mirror.
The toughest part of the job, after cleaning the duct tape residue off the door was re attaching that plastic triangle piece to the inside of the door.
Remove screws in arm rest, on trailing edge of door(facing rear), behind cover in door handle housing, and behind pop out trim piece on front edge of door. That screw holds the bottom of the triangle trim piece.
Then push up on triangle to remove.
This will expose 4 screws that hold on the mirror. Remove them.
The mirror will now be loose.
I used a putty knife to help around the edges of the door panel to pop the panel off of the friction fit connectors.
Remove the cup behind the door handle.
Lift up on the door panel It will come right off.
The panel is connected by your power window wires so don't let it fall. I just hooked the panel on the door handle.
Use a razor to slice the gunk holding the plastic water barrier to give you access to the electrical connection if you have a power mirror. My is mirror is power but not heated but I can't imagine the connector is different.
Carefully disconnect the plug. The mirror is now free.
Fit new mirror with holes and supplied weather strip.
Reattach without over tightening.
And reverse obove steps to finish.
Not that difficult.
V X
Old Dec 13, 2007 | 11:23 PM
D_L's Avatar
D_L
ford parts
Old Dec 15, 2007 | 12:09 PM
i1dery's Avatar
i1dery
you went through all that?
I replaced my wifes mirror in what sounds like half the time by popping off the
triangle piece taking the screw out unplug wires and install new one in backwards order
hmmm,
ChadTaylor
Mar 17, 2015 07:59 AM
paraskr
Feb 9, 2013 01:04 PM
Something D
Dec 12, 2006 03:24 PM
