6" Fabtech Lift noises
Old May 6, 2007 | 06:54 PM
Nico's Avatar
Nico
I have a 2006 F150 crew with a 6" fabtech lift. I can hear a clicking noise in the front end whenever I brake hard;(i.e. decelerating off highway, abrupt stop) it is apparent that the transfer of weight in these situations is causing the noise. I have retorqued the kit twice. I love my truck but this is driving me crazy.
Old May 6, 2007 | 07:50 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
could be:
tie rod ends
brakes chattering
control arm bushings
sway bar bushing - most likely IMO
body bushings
tires rubbing the wheel well
Old May 7, 2007 | 12:29 AM
T-B_MN's Avatar
T-B_MN
+ 1 for sway bar
Old May 8, 2007 | 08:02 PM
04fx46's Avatar
04fx46
this probably don't have anything to do with your noise but make sure your front driveshaft has the slip-joint towards the transfer case if its toward the front the yoke hits the sway bar.
Old May 10, 2007 | 01:06 PM
one5150fisher's Avatar
one5150fisher
make sure that the sway bar brackets are in the right way and that the sway bar is tight to the lower a arms. This is a tough one to figure out with out some more description. Is it happening with the wheels turning or just a one time clunk, is it when the suspension compresses in the front, are you sure it in the front of your truck. Does it happen under acceleration
mnm27mnm
2004 - 2008 F150
May 13, 2020 09:45 PM
kxriderforlife
Jul 23, 2017 09:45 PM
Mxsledder
Feb 22, 2017 06:30 PM
68cabby
Feb 12, 2017 02:11 PM
chazms
Apr 25, 2002 03:23 PM
