Shock failure
Old May 6, 2007 | 06:25 PM
redsplashman's Avatar
redsplashman
Shock failure
Yesterday found a big oil stian under my driver side rear wheel. Climbed under and found shock leaking lots of oil. Never had this happen befor. Truck has only 7K and hardly ever has anything in the bed. Called for appt. at dealer service and will take it in Tues. after work. Should they change both rear shocks under warranty or just the one ? Anyone else know of this problem ?
Old May 6, 2007 | 06:42 PM
screwy's Avatar
screwy
They will only change the defective shock. Just sounds like you got a bad one, it’s bound to happen to a few.
Old May 6, 2007 | 07:40 PM
WhëëlMå1's Avatar
WhëëlMå1
The stock shocks are garbage. This would be the perfect opportunity to put a nice aftermarket set on, but thats just me.
Old May 6, 2007 | 07:45 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
You can spend the $100 or so to get 2 good shocks and install them yourself, or let the warranty cover it and then replace them again at the 50,000 mark or so...
I'd get some good Rancho shocks myself. the 5000's are pretty good
Old May 10, 2007 | 02:28 PM
Danny0295's Avatar
Danny0295
Same thing here. I just took truck in and they found the right front shock leaking. They were quite shocked, as was I, and they replaced it for free since it was still under warranty.
Old May 10, 2007 | 02:47 PM
WhëëlMå1's Avatar
WhëëlMå1
Originally Posted by Danny0295
They were quite shocked...
Who writes your material?
Old May 10, 2007 | 03:11 PM
redsplashman
When I took the truck to the dealer Tuesday they saw that it was indeeed leaking. They informed me that they don't stock replacements so they are ordering 2 so that both rear ones will be replaced when they come in.
Old May 10, 2007 | 08:31 PM
Gevans17's Avatar
Gevans17
had to have the OEM Bilsteins on a 02 Chev Traiblazer replaced due to leaks at 17,000 miles.
Truck Builder 1
28
Mar 11, 2019 02:07 PM
gwcloud
Sep 22, 2014 05:19 PM
Gary Lewis
40
Feb 8, 2013 09:17 AM
Gage2502
Mar 19, 2011 08:54 PM
jstutz101
Jul 18, 2006 10:06 PM
