Anti-theft solution
Old May 6, 2007 | 08:44 PM
rusty7983's Avatar
rusty7983
move to somewhere where your truck won't get stolen. make your truck as ugly as possible, then noone will want it. i have an 83 ranger from when i was up north, faded paint, rust and rot galore. i leave the keys in it. nobody wants it, but me.
Old May 6, 2007 | 09:48 PM
kilog55's Avatar
kilog55
my truck is so loud i would know if someone was gonna take it, plus it takes forver to get it to run right/smooth they wouldnt get far
Old May 6, 2007 | 10:39 PM
Purely Ford's Avatar
Purely Ford
I just take the working rotor out of the distributor and install a non working one and the truck simply will not start. I really don't think a thief will take or have the time to track down the problem. Besides, even if someone is lucky enough to find the problem, will they have the part on them?
Also, a rotor will fit in your pocket.
Old May 6, 2007 | 11:14 PM
Mil1ion's Avatar
Mil1ion
Originally Posted by One79one71
Listen, putting a switch in the starting or ignition circuit wont do a thing, since anyone wanting to steal the truck would be by-passing that anyway. It only takes a screwdriver and a jumper wire too crank these sweet crafts
Unless the hood won't open.
These days I am more worried of someone in a tow truck with dollies doing the theft for stripping......not someone going for a joy ride.
Locking Hood
Ignition disconnect
Steering wheel Bar
Alarm system
Alarm system stickers
......all useless when someone has a tow truck doing the deed.
Otherwise you are only keeping honest thieves at bay.
You know how many threads on FTE about no start have been from >>> Ignition disconnection device ?
Old May 6, 2007 | 11:32 PM
IowaTower's Avatar
IowaTower
Wouldn't even need dollies for 4wd or manual trans. Auto takes just a few moments longer to pop the linkage.
A mod for the door-locks would be helpful -- they're a joke. Removing the lock-ring from the steering-column, if equipped, makes it a further PITA. Or installing one, and always, always park with the wheels cranked. Park with the front inaccessible to another vehicle. Lock the hood in some fashion -- I picked up several 70s vehicles a couple summers ago due to missing carbs.
Nothing will stop a determined tow-truck, but you can definitely make things difficult.
Old May 6, 2007 | 11:36 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
I like the coil switch or fuel line shutoff valve ideas. But if someone really wants it they are gonna take it. Me, I have security cameras set up so if someone decides to help themselves it will be recorded.
Old May 7, 2007 | 11:36 AM
bigperm2's Avatar
bigperm2
Its been said a hundred times, nothing will stop a determined thief. However, I think our trucks are often stollen because the are so easy to steel. A simple ignition kill switch is still much better than nothing. For more serious theft prevention, How about a denver boot? can't tow it or drive it. I also have been considering Lojack or some other tracking system. The good news on those, is hopefully, if someone stole my truck, there would be a good chance of catching the SOB. Of course they would probably only spend a night in jail with a slap on the wrist, but that is a whole different story!
Old May 7, 2007 | 11:38 AM
kilog55's Avatar
kilog55
also you dont need to hotwire or jump anything all you need is.........PM me and ill tell ya cause i aint gonna give inside info. or maybe i wont tell you. it has to do with a key though
Old May 7, 2007 | 11:41 AM
Broken40's Avatar
Broken40
Why don't you try locking your truck up, that's helped me before............lol
Old May 7, 2007 | 11:47 AM
kilog55's Avatar
kilog55
locks only keep honest people honest. or slow down the determined
Old May 7, 2007 | 01:47 PM
Homelessduck's Avatar
Homelessduck
I have an electric fuel pump on mine. Only I know what all of my switches go to, so if anyone tries to take my truck they will get about 20ft down the road and it will die.
Old May 7, 2007 | 03:54 PM
tcbofade's Avatar
tcbofade
Originally Posted by Mil1ion
...You know how many threads on FTE about no start have been from >>> Ignition disconnection device ?
My friends Dad did that to himself...he was going away for a few years, and wired a kill switch into the ignition circuit so no one could start his truck.
He came home and couldn't start it either. Had half the truck apart when he found the switch that HE installed...
Old May 7, 2007 | 04:37 PM
  #28
czaroc's Avatar
czaroc
I think it would be better to put a disconnect on the power to the Duraspark Module rather than the coil. There are way to many wires running in there to trace out and the truck wouldn't go nowhere.
Old May 7, 2007 | 09:21 PM
  #29
hotroddually's Avatar
hotroddually
i have an alarm,the club,ignition imobilizer,but the best deterant of all has to be my two rottweillers in the truck.they are very selfish they dont share well with anyone.
houstontxex
Sep 3, 2012 08:27 PM
SNIPER168308
Oct 1, 2011 06:37 PM
Ford RV'er
33
Nov 26, 2008 09:09 PM
larana
1997 - 2003 F150
Jan 8, 2007 02:02 PM
seawulff
27
Sep 5, 2005 11:33 PM
