need new trans?
Old May 6, 2007 | 01:02 PM
someday's Avatar
someday
need new trans?
well after busting my but changing a motor mount that i thought was causing a bad vibration turns out there is a problem with the trans...the truck is an 89 f350 drw 460 2wd c-6? or AOD (PRN(D)D1)...the truck has a terrible vibration from the start and pretty much undriveable...it worked better with the modulator disconnect so i replaced it with a new one with no improvement...with the mod disconnected i can drive it by starting in 1 and then shifting it to D and (D) does not work...if i stop i have to start in 1 again...sometimes it shutters a bit but it works....what could be the problem? if i need a new trans, where can i buy a heavy duty trans?
Old May 6, 2007 | 03:00 PM
someday's Avatar
someday
would a new shift kit solve the problem?
Old May 6, 2007 | 04:23 PM
fordfaninIL.'s Avatar
fordfaninIL.
In 89 you could get an e4od or a c-6. Since you say that you unhooked the vac. modulator, I would say that you have the c-6. First I would check the fluid and make sure it is full, looks red, and does not have a burnt smell to it. If all of that checks out then drop the pan and check for metal. If it is full of metal then I would suspect an internal problem. With the vac. mod. hooked up will the truck shift or does it stay in first? Make sure that the vac. line did not come unhooked at the intake.
Old May 6, 2007 | 06:12 PM
someday's Avatar
someday
i always thought it was a c6 but i saw a thread showing my dash config was an AOD...fluid is in pretty good shape and level (mobil 1) changed maybe a year or so ago... when the vac mod was connected the fluid was bubbly on the stick...when i get time ill drop the pan for a visual inspection...with the vac mod connected the truck would shutter like hell and after a lot of feathering of the throttle i think it i could get up some speed and second gear but i cant remember for sure
Old May 6, 2007 | 07:14 PM
fordfaninIL.
It is possible that you have a bad engine miss, I've even seen a bad cat. converter cause similiar problems.
Old May 7, 2007 | 04:16 AM
someday's Avatar
someday
certainly not engine, runs almost perfect w/o vac mod connected
Old May 7, 2007 | 04:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1980/89 Ford Light Truck Parts Catalog shows two Automatic Transmissions for an 1989 F350 with a 460. C-6 or E4OD (NO AOD's listed). C6's use a modulator valve, E4OD's do not. There are two different modulator valves used for 1989 C6's with a 460.
D4TZ-7A377-A .. Modulator Valve ~ Black Band ~ (Motorcraft TM-30)
OR
D7OZ-7A377-A .. Modulator Valve ~ GREEN BAND ~ (Motorcraft TM-43)
Band refers to an ID stripe around the diameter of the valve.
Old May 7, 2007 | 05:17 AM
someday's Avatar
someday
when i bought the new vac mod from the dealer he said it was the only one listed (black stripe)
Old May 7, 2007 | 05:28 AM
NumberDummy
In 1989, there were two listed. It's possible Ford replaced the green with the black, but I don't have that info, sorry.
EDIT: Motorcraft website shows GREEN stripe D7OZ-7A377-A as obsolete or replaced by a new number.
davescoolcars
17
May 17, 2014 12:46 PM
Abatick
Oct 18, 2012 06:47 PM
deanj
Nov 26, 2005 11:03 PM
bagodonuts
15
Feb 18, 2004 07:24 PM
