Headlights Flickering ?
Old May 5, 2007 | 10:37 PM
Bill W's Avatar
Bill W
Question Headlights Flickering ?
Hi Guys, SO Just got the 66 F100 running and this evening turned the lights on when running and they go from bright to dim and the amp guage jumps to the positive (about half way to 30) What should I check, I dont know where to start. thanks
Old May 5, 2007 | 11:01 PM
Tedster9's Avatar
Tedster9
Hm - not sure on this but the floor switch is a culprit sometimes. I found a lot of archived posts on those on a search oncet.
Old May 6, 2007 | 12:48 AM
judi48's Avatar
judi48
Grounds, grounds and more grounds. I had to run a separate ground wire from the alternator to the regulator to get mine to stop flickering. I don't have an alt guage, just the idiot light, but it and my dash lights all flickered. Got a good ground and all is well. I have found that 90% of the time, electrical problems are a ground issue.
Happy hunting...
Old May 6, 2007 | 01:26 PM
airharley's Avatar
airharley
I agree with the other two. The wiring schematic always shows a seperate ground dedicated for the alt to the reg and then to chassis. Your healight switch and connector can also have dirty or loose contacts as was in mine as well.
Old May 7, 2007 | 08:31 PM
Darth Cobra's Avatar
Darth Cobra
Dont forget the headlight upgrade.
https://www.ford-trucks.com/index41.html
Chris
Old May 8, 2007 | 12:36 AM
judi48's Avatar
judi48
Chris,
Thank you. I've not seen that fix before and it sure makes sense to me. Thant's why I love this site. Somebody ALWAYS has a better idea, LOL
awright48
2009 - 2014 F150
Feb 16, 2014 08:13 PM
brcwelding
Apr 21, 2012 08:45 AM
navi24
Jun 24, 2011 10:14 PM
ford390gashog
Sep 10, 2004 07:30 PM
TonyG
Mar 26, 2002 06:35 PM
