Pillar gauge pod problems !
Old May 5, 2007 | 08:14 PM
fd1109's Avatar
fd1109
I'm trying to finish the installation on a 4 gauge pillar mount pod and having a problem with drilling the holes for the push pins because of the angle and being so close to the windshield . My pod came with several plastic push pins that are installed after a 3/16 hole has been drilled . Does anyone have any suggestions or any tips or mayby even a different idea ?
Old May 5, 2007 | 08:44 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Are you using a right angle drill? If not Lowes or Homedepot has right angle attachments for $30 bucks that chuck right into your existing drill.
Old May 5, 2007 | 08:47 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Are you not removing the stock A-pillar after first marking the holes? Shouldn't need a right angle drill then but be careful not to break the stock one like I did. Look in my gallery. Luckily the new pod covers that fudgeup nicely. Good luck.
Old May 5, 2007 | 11:47 PM
mech2161's Avatar
mech2161
Don't drill the holes! Use double sided tape.
Old May 6, 2007 | 02:18 AM
foxracer800's Avatar
foxracer800
Like mech said, you don't need to drill the holes. But if you do, remove both the stock pillar and the one for the gauges from the truck and drill them, then stick the whole thing back in.
Old May 6, 2007 | 04:23 PM
fd1109's Avatar
fd1109
Will the double sided tape fail when it gets hot during the summer ?
Old May 6, 2007 | 04:29 PM
fd1109's Avatar
fd1109
Tenn01psd , you asked if I was marking the holes first before taking the original pillar off , can you explain ? The old one is mounted with push clips and guide pins that are in the back , probably the same as my psd is also a 01 .
Old May 6, 2007 | 09:27 PM
Tenn01PSD350
Well, if you plan to use the push pins that match the pillar, you may find some of the same things out I did. The gauge pod will fit over the stock A pillar just so. Drilling blind is a no-go because you don't know what is behind the stock pillar until you pull it and look. Also, who wants to buy an angle bit? So, I did this:
1. Positioned guage pod over stock to see how it fit.
2. Pulled stock pillar and looked where I definately did not want to drill.
3. Put stock pillar back on and drilled 4 holes in gauge pod.
4. Put gauge pod over stock pillar and marked holes on stock pillar through gauge pillar.
5. Pulled stock pillar and drilled marks and holes for wiring.
6. Wired up the works and installed using temp bolts or screws until I was sure all was functioning well.
That's the best I can remember. I studied the install instructions from Black Cloud Diesel and ITP for quite some time while they were shipping. Black cloud's pillar stuff is better.
Hope this helps and good luck.
Old May 6, 2007 | 09:39 PM
jtharvey's Avatar
jtharvey
Good quality double sided tape shouldn't lose its stick in the summer. I like that idea and may have to run with it. I've got one pin missing and my gauge pod moves a little which bugs me.
Otherwise, pull the stock pillar off and drill the holes.
Old May 7, 2007 | 01:19 AM
DieselFuelOnly's Avatar
DieselFuelOnly
You'll eventually need a right angle drill... so this is the PERFECT excuse to go out and buy a new toy, oh um I mean tool.
Old May 7, 2007 | 05:54 AM
fd1109's Avatar
fd1109
Tenn01psd350 , are you saying that your gauge pod is mounted over the stock one or are you just using it as a template ?
Old May 7, 2007 | 08:29 AM
kennedyford's Avatar
kennedyford
Easy fix, use a drywall screw and do that by hand then remove and push in your plugs.
Old May 7, 2007 | 02:18 PM
MLCRI$I$ II's Avatar
MLCRI$I$ II
If you use double stick tape, buy the 3M RED tape used to apply trim insignias and badges on the OUTSIDE of cars. Clean all surfaces with isopropal alcohol and that puppy will never come off!. Hope this helps. 3M is the best, hands down.
Old May 7, 2007 | 02:19 PM
MLCRI$I$ II
Thumbs up
sorry about double post.
Old May 7, 2007 | 02:26 PM
Tenn01PSD350
Yes, right over the stock one. The gauge pod mounts to the stock A-pillar which has it's own mounts. At least that is how mine was and most are IIANM.
