Pillar gauge pod problems !
Old May 7, 2007 | 02:27 PM
Kwikkordead's Avatar
Kwikkordead
I'm with KennedyFord on this one. I used a short self tapping SS screw and anchored the whole assembly using just one screw mounted out of sight around the corner below the sun visor hinge. I pre-drilled the guage pod first and then ran the screw into the factory A-piller trim.
Old May 7, 2007 | 02:28 PM
natewoz's Avatar
natewoz
Originally Posted by fd1109
Will the double sided tape fail when it gets hot during the summer ?
I second the 3M tape. Some of their stuff is incredible. Their VBH line of foam-double stick tape is used to build entire semi and horse trailer bodies with no mechanical fateners. I used the 3M tape to re-skin a 52' Wilken's walking-floor semi trailer last summer. After a year of being used off-road in logging and the trailer taking a lot of twisting forces, not a single joint has moved or failed.
Old May 7, 2007 | 02:30 PM
Tenn01PSD350's Avatar
Tenn01PSD350
[QUOTE=Tenn01PSD350] Black cloud's pillar stuff is better.
QUOTE] BTW, I mean their install instructions on the gauge pod at their site, not that they sell better equipment.
Old May 7, 2007 | 02:43 PM
rbaker6336's Avatar
rbaker6336
I tried the 3-m tape and fell off in a week after it got hot,then drlled 4 holes n the pod and pot srews in
the back screws go i easy by hand ,think I used a 1\4 in rathet with a phillips bit
Old May 7, 2007 | 03:06 PM
John311t's Avatar
John311t
I went to home depot and i use there 3M double sided outdoor/indoor tape. My instrument cluster bezel came with some 3M 2 way tape, but it was no good, so i peeled it off and used the outdoor/indoor tape done. That sucker hasnt moved since. My A pillar pod is mounted with one push pin in the top, its mounted to the original Apillar trim.
Old May 7, 2007 | 07:37 PM
fd1109's Avatar
fd1109
Now that I know that the gauge pod goes over the stock one I think its all down hill from here . My directions were not very clear but with the tips I'm good to go . Thanks alot
Old May 7, 2007 | 07:43 PM
Tenn01PSD350
Apparantly you don't have instructions for your pod. Have a look here clicky, and decide how you want to go about it.
01PS
New Mexico Chapter
Jun 14, 2013 02:14 PM
Sparkplugless
May 29, 2009 01:31 AM
viperbluelx
Jul 2, 2007 04:07 PM
VTRACER
2004 - 2008 F150
Jun 19, 2006 10:06 PM
LAUDY
Jan 12, 2004 07:12 PM
