boost on 04 6.0
Old May 5, 2007 | 03:54 PM
ptr34's Avatar
ptr34
boost on 04 6.0
It was always around 28 to 30 and then it started hitting about 35 psi at WOT. It also blow the head gaskets.
Old May 5, 2007 | 04:33 PM
blackhat620's Avatar
blackhat620
ptr34,
A little more info on the truck would be helpful, ie build date, mileage, tuned or not, any other mods.
But i am betting on sticking turbo blades causing an overboost situation. This should be a warranty item. If they cannot clean the turbo sufficiently, they will replace it. Also if they are doing head gaskets for you, see if they will install ARP headbolts if you supply them.
Old May 6, 2007 | 03:58 AM
darsey715's Avatar
darsey715
lol .
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
