Coolant leak
Old May 5, 2007 | 02:18 PM
ACarbone624's Avatar
ACarbone624
Cool Coolant leak
I have coolant leaking from the rear of the engine, near the top on my 94 Explorer. Where could it be coming from?
Old May 5, 2007 | 06:15 PM
steve(ill)'s Avatar
steve(ill)
heater hoses at the fire wall are one good place to start.
Old May 5, 2007 | 07:21 PM
quicklook2's Avatar
quicklook2
more info is always better when asking a question.
describe leak and what you see and have done better.
Old May 5, 2007 | 09:21 PM
ACarbone624
its not the heater hoses, I checked those....its coming from the top rear of the engine on the passenger side....runs down the oil filter and leaves a puddle in the driveway
Old May 5, 2007 | 09:35 PM
aquanaut20's Avatar
aquanaut20
the 4L OHV engine has a water passage at the rear passenger side, they leak at the lower intake manifold gasket or the frost plug.
A flash light and a mirror will help you locate the leak.
Modify and old pressure cap, remove the bottom seal, install an air hose nipple in the cap. Pinch off the overflow tube and pressurize the radiator with the modified cap and a 5 - 7psi air supply, this way the water that drips on you will be cold not hot.
Alternate method, install a flush kit, connect to water supply and go look for leak. Best use a pressure regulator (find this at RV place) on the water supply to keep the pressure lower than the vehicle's system rated pressure
Good luck, let us know what you find
Old May 5, 2007 | 11:24 PM
mrshorty's Avatar
mrshorty
If you have an Autozone convenient, they have a cooling system pressure testing kit as part of their loan-a-tool program.
Old May 6, 2007 | 09:33 AM
quicklook2's Avatar
quicklook2
or any radiator shop can do the same thing.take a mirror and strong flashlite with you.
Old May 6, 2007 | 09:50 AM
ACarbone624
Thanks guys...I'll have a chance later to check it out. I'll let you know what I find.
Old May 7, 2007 | 08:54 PM
ACarbone624
looks like the lower intake is leaking....how much trouble is it to fix?
Old May 7, 2007 | 10:08 PM
aquanaut20's Avatar
aquanaut20
Last one I did, 3hrs start to finish, and $100cdn.
I removed the hood and tires, set the truck down on the ground, easier than climbing over fenders. Be meticulious in cleaning the heads and manifolds, set gasket silicon on joints and take your time setting the lower gasket, if it moves it may leak at the same spot(binderdondat).
Good luck, let us know how you make out.
Old May 7, 2007 | 11:16 PM
mrshorty's Avatar
mrshorty
I just did the intake gasket on my '92. I'd call it 6-8 hrs my first time. If I did enough of them, I could probably get it down to 3-4. Probably lost 1 hour searching for bolts that fell off. One of the valve cover bolts fell out and landed on top of the oil filter mounting thing, and another fell out and landed on the transmission. I always hate that, because it seems I lose so much time trying to find and retrieve bolts when they do that.
So far, two weeks after the fact, I don't see any leaks, so I think I got it to hold. All in all, it wasn't too bad. If that's where it's leaking, and you're reasonably good with tools, you should be ok with this one.
I may have to try this next time I get under the hood. As you might guess from my username, I don't always enjoy reaching over the fenders into the hood. I guess you would have to have a wood block (4x4 or so) to put under the i-beams so the knuckles/ball joints aren't right on the ground, but that would make things easier to have the front end lower.
Old May 8, 2007 | 12:10 AM
aquanaut20's Avatar
aquanaut20
I just put a slab of particle brd under the rotors and set them down slow, kids said it looked like the exploder was begging. Done this on both my exes now, twice on the 97, gasket slipped and curled, leaked at back corner.
4 bolts and the hood is out of the way.
