1978 - 1996 Big Bronco
83 with no gauges..
Old Mar 6, 2001 | 09:35 AM
gotti's Avatar
gotti
83 with no gauges..
My Bronco's speedometer and the RPM and gas gauge do not work... does anyone know an easy way to fix this? Is it a known problem?
Are aftermarket gauges hard to install?
Thanks.
Old Mar 6, 2001 | 12:00 PM
odinmurphy's Avatar
odinmurphy
83 with no gauges..
Check all your fuses to see if any are blown. If this is not the case and easy fix is just to go to salvage yard and get the "guts" of the dash out of another bronco or pickup. Not very hard to do at all.
Good Luck
Murph
Old Mar 6, 2001 | 02:23 PM
galaxiefiveohoh's Avatar
galaxiefiveohoh
83 with no gauges..
Slow down there! The fuses for the dash can be good and the gauges still not work if the voltage regulator for the gauges is bad. Before spending all that $$$$$$ at the junkyard, check out the regulator!!!!!!!
Old Mar 6, 2001 | 03:12 PM
gotti's Avatar
gotti
83 with no gauges..
Hate to sound dumb.. but were is the regulator?
Old Mar 8, 2001 | 08:18 AM
gotti's Avatar
gotti
83 with no gauges..
Back up^
Old Mar 12, 2001 | 10:26 AM
gotti's Avatar
gotti
83 with no gauges..
Anyone know where to find this regulator?
Old Mar 12, 2001 | 02:51 PM
fast freddie's Avatar
fast freddie
83 with no gauges..
I haven't heard of a voltage regulator for the gages but that don't mean there's not one. I just bought a 1991 and my fuel gauge stays on emty if the truck is running and drifts up to about a quarter if the ignition is off. Also the oil pressure gauge comes up to about a quarter of the scale when it's running and stays there regardless of engine rpm or engine temp. Don't know if the two are related but I guess if there is a regulator somewhere it could cause these kinds of problems.
Old Mar 26, 2001 | 04:23 PM
83bigbroncoguy's Avatar
83bigbroncoguy
83 with no gauges..
I have the same proble with my '83, so the problem can't be that uncommon. Don't feel bad, I don't know where the regulator is either.
Old Mar 26, 2001 | 09:53 PM
Bob_VT's Avatar
Bob_VT
83 with no gauges..
Well the speedometer is mechanical driven by a cable and the tach is not run through the regulator for the guages.
The regulator for the gauges controls the radio suppressor, fuel, oil light or gauge and temp gauge.
I would try a new gauge panel from a junkyard, they are cheap.
Old Mar 27, 2001 | 07:53 PM
Torky's Avatar
Torky
83 with no gauges..
