I have a '91 351 Bronco and have a couple of questions:
1. Without a lift kit, what are the largest tires I can put on my Bronco?
2. After driving for about 1/2 hour 2 lights light up on my dash, the rear antilock light and the e-brake light. Any ideas as to what would cause this? I don't have antilock brakes so I have no idea why that light would come on.
with no spring sag..32's..depending on tire width...i have a 96 with GY 32x11.50's on 8" stand offset are rims.....just needed to adjust the driver's side bumper up a bit and trim a small piece off the valance..also, see here for more tire info, etc on broncos:
I've got a '93/351W w. 33" Pirelli A/t's that rub on the swaybar at full ****. Misses the front bumper barely. Haven't wheeled w. them yet. Though I'm eventually getting a 4" lift.
Chris
Here's my pic. Another MBB:-) http://mybigbronco.com/ponyman/ and
http://www.superford.org/cgi-bin/sf.cgi?uid=default&vr2=1&ID=1361
Your 89 should have rear wheel anti lock. look at the top of the rear differential, just to the front of center, should see the sensor sticking out with a 2 wire cable attached.
