Door Seals Please help
Old May 4, 2007 | 11:32 PM
Pa's64f100's Avatar
Pa's64f100
The door weather seal I got from lmc truck I'm having a problem with . The door will not make it to the 2nd click on the latch and it sticks out to much. I can push it in till I am as blue as the thuck and it ain't gonna go. has any one else had andy problems with there's?
Old May 5, 2007 | 06:04 AM
jowilker's Avatar
jowilker
I have heard that LMC sells cheap rubber, Dennis Carpenter makes/sells the best through his dealer network.
Slam the door and see if you can make it catch, the rubber will have to mold itself to the opening and should be a lot better in a couple weeks.
John
Old May 5, 2007 | 07:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Original part numbers:
C1TZ-8120530-A .. Right Door Weatherstrip
C1TZ-8120531-A .. Left Door Weatherstrip
Some of the after market weatherstrips are made in China, are too fat, or too long. Dennis Carpenter makes the w/strips from the original molds. The weatherstrips will always be a bit larger than what comes off, because the old ones will flatten out over time. What you describe tho, is poor quality w/strips. lmc is not a FTE sponsor.
Old May 6, 2007 | 11:45 AM
FLOJ0620's Avatar
FLOJ0620
Door Weatherstripping
Amazing. I Just Finished Struggling With Replacing The Drivers Side Weatherstripping On My 63, Using Lmc Truck. And I Had The Same Problems You Did. I Ended Up Taking The Door Off The Hinges, And Used Small Sheet Metal Screws To Attach. Then I Trimmed A Little Off The Front Section, By The Curve Near The Window, Where It Was Squeezing The Most, And That Helped. Good Luck.
John
Old May 6, 2007 | 06:49 PM
jcs1966's Avatar
jcs1966
i had to slot the holes in the cab to make it go shut and be flush in the outside, i tried to align my door the whole wah around and i dont think it was ever right when it was new!
bamaboy_1966
1961 - 1963 F100 Unibody
Oct 5, 2014 09:08 PM
EP145
Jun 18, 2013 12:53 PM
cbzdel
Jan 14, 2012 06:48 AM
White Knight 2011
6.7L Power Stroke Diesel
Jan 12, 2011 11:17 PM
joe hoffman
46
Oct 27, 2006 07:30 PM
