1978 - 1996 Big Bronco
fuel ?
Old Mar 25, 2001 | 10:43 PM
1989xlt's Avatar
1989xlt
fuel ?
hey I picked up an 89 xlt and eveything was running fine when I took it out on the freeway and after about a 100 miles it started to lurch at first I thought it was the trans but after I got off the freeway and came to a complete stop and went to restart it was like it wasnt getting enough fuel I had it floored and it was hesitating and such I got it up to speed but it took awhile and it did it all the way back home any help would be greatly appriciated thanks
Old Mar 26, 2001 | 03:30 PM
Bob_VT's Avatar
Bob_VT
fuel ?
Fuel Filter - Change it. I change mine at every oil change or I encounter the same problems. You might have sediment in the fuel tank. Filters are cheap and easy. I would try that first.
Old Mar 27, 2001 | 10:32 AM
dragonman's Avatar
dragonman
fuel ?
I have a 1989 Bronco with the 351 and was experiencing the same problem. Some members have suggested replacing the fuel pump on the outside of the tank, others suggested replacing the one in the tank. Others suggested replacing the fuel pump relay. I ran into the cause of my problem by accident. I found the wires in the socket that the relay plugs into were full of corrosion. I replaced the pigtail and haven't had a problem since. These are the only suggestions I can give you. I know a lot of people have had this problem with their broncos so you're not alone.
Old Mar 27, 2001 | 06:35 PM
Bob_VT's Avatar
Bob_VT
fuel ?
Old Mar 29, 2001 | 12:57 PM
1989xlt's Avatar
1989xlt
fuel ?
thanks for the help guys will do and let you know what happens
Kafn8td
6.7L Power Stroke Diesel
Oct 15, 2016 06:53 PM
Brian from the crypt
15
Apr 11, 2016 08:54 AM
78ems
15
Nov 25, 2013 10:49 AM
BENSFORD
6.4L Power Stroke Diesel
Feb 9, 2009 11:02 PM
sharky
Jun 13, 2006 06:08 PM
