I have installed a t18 4 speed replacing my old 3 speed in my 80 f100.
I got a good deal on it but... the kid I bought it from sawed about a foot off the shifter handle and had a hurst shifter handle glued on the shaft.
Is there any problems I might face removing the shift handle to replace it or to weld a longer shaft back on? I heard you should have it parked on level surface so the gears don't slip back when you remove the shifter. Also is all I have to do to remove it is unscrew the cup, remove the washer and spring, and then remove the pin on the side then lift up and out? I'm am really nervous about doing this.
