i need some help
Old May 4, 2007 | 05:05 PM
rustee90-150's Avatar
rustee90-150
i need some help
i have a 90 f150 302 its idling poorly it normally idels at 7000 if i just touch the throtle a little bit say bring it up to 8000 quickly it idles back down but goes down to about 500 then bounces around from 5 to seven it does that for a minute then settles back down at 7000 i changed the idle air control motor with one of another of the same truck and it still did it . anyone know or have an idea of whats going on ? thnxs shawn
Old May 4, 2007 | 05:18 PM
quicklook2's Avatar
quicklook2
idles at 7000 rpm!!!
i do not think so, nor does it rev to 8000 rpm.
Old May 4, 2007 | 06:30 PM
rustee90-150
sorry one to many zeros
Old May 4, 2007 | 08:20 PM
Popa Tim's Avatar
Popa Tim
check for vacuum leaks
Old May 4, 2007 | 11:54 PM
eric f150's Avatar
eric f150
MAP sensor?
try unpluging it and see what happens.
Good Luck
Old May 5, 2007 | 06:31 AM
rustee90-150
ive checked for vacuum leaks couldnt find any. where is the map sensor?
Old May 5, 2007 | 07:05 AM
eric f150's Avatar
eric f150
on the firwall about the pasenger side windshield wiper, it has a little plug and a vacum line, ive heard not to unplug or plug stuff like that bake in while its running, so i would saystart it then unplug it and restart it again and see if theres any difference.
Old May 5, 2007 | 12:51 PM
biggreentank's Avatar
biggreentank
My friend's truck would started idling at 2000 RPM or so. That's what it sounded like anyway. It needed a new TPS.
Old May 5, 2007 | 02:04 PM
rustee90-150
tps is that the throttle posistion sensor?
Old May 5, 2007 | 02:05 PM
rustee90-150
if i disconect the pcv valve from the hose it is attached to it idles fine no bouncing but it sits at 1000 rpm .
MT4x4guy
Sep 16, 2013 01:04 PM
rbegga
Modular V10 (6.8l)
Oct 14, 2007 10:35 AM
76F250HighBoy
1978 - 1996 Big Bronco
Jan 21, 2005 08:09 PM
DT 466Man
Aug 11, 2003 09:42 PM
RGAZ
May 8, 2000 12:43 PM
