code 0175 bank 2 rich
Old May 4, 2007 | 04:50 PM
MYE150's Avatar
MYE150
Smile code 0175 bank 2 rich
I have been hunting down this problem. Engine rebuilt 15000 miles ago. 158,000 on odometer. It has run rough eversince the rebuid. It originall threw a bearing and had apparently been rebuilt before I bought it at 80,000. I have since change the coil pack twice, the IAC (cleaned old one and it worked better - new one was no better than the cleaned one) new plugs and wires, new #1 o2 sensors on both sides (did nothing)
Engine Idles rough and stalls out sometimse giving me the code sometimes not giving the code. Most of the time the code will come up with out stalling. The engine runs great in higher speeds, it is a dog at idle and acceleration below 20mph. It also runs much better when the weather is colder. I am in Miami this does not happen too often.
Any ideas are welcome. I have a mechanic who has been helping with this and he can nolonger come up with any other solutions other than the computer.
Old May 4, 2007 | 09:17 PM
MYE150's Avatar
MYE150
I could not figure out how to edit a post so I will do it here.
The MAF has been replace, Fuel filter & pump replaced
Old May 7, 2007 | 09:30 AM
BrianA's Avatar
BrianA
Have you done a thorough check of all vacuum lines. Looked for leaks, cracked lines, loose lines, etc.?
Since it has been rough since rebuild, makes me wonder if it is a vacuum related problem.
Old May 7, 2007 | 05:32 PM
MYE150's Avatar
MYE150
BrianA
Thanks for the reply. Yes the vacum lines have been checked and check out OK.
Update on what has been done. Since the time I last posted I went to reset the computer which was on the to do list already, I was thinking dirty high resistance on the connector. Good connection but the computer did get reset. Jacked it up to do an oil change and 10 minutes later I am looking at antifreeze all over the driveway. Did the thermosat, and checked the EGR valve while I was there. Found that the mount to the EGR to the block the screws were stripped and was leaking. (This is also right where the thermostat was leaking.) Fixed all that. Better but still has the rich problem. Today I got the 2 downstream O2 sensors and went to put them in right after getting home. Exhaust still hot. Did bank 2 first, hot but could be handles. Then I did bank one - This one was much hotter than the other side. My suspisions now lead me to a clogged Cat. Is this correct in my thinking, or am I going down the wrong track? Could the added back pressure create a rich condition?
Coresair
33
Jun 22, 2016 06:00 AM
Illbethejudge
Oct 2, 2014 10:33 PM
Shakedown St.
Jun 1, 2010 11:46 AM
vintageant
Aerostar
Nov 2, 2005 09:23 PM
RADVRA
1997 - 2003 F150
Aug 14, 2003 11:16 AM
