Aerostar Ford Aerostar
Bad Idling - again!
Old Nov 2, 2005 | 08:42 PM
vintageant's Avatar
vintageant
Bad Idling - again!
Out of touch without power for past 10 days in Miami, thanks to Hurricane Wilma.
Over the past few weeks I've posted on a couple of threads about my idling woes on my 93 4.0 with 156k miles. Engine runs fine once above about 1800 rpm, but idling remains rough. In fact have to put it in N when at a stop. Over the last 3 weeks, I've done:
New OEM plug wires
New MAF
New IAC
Cleaned throttle body and passage to IAC
New O2 sensor
New PCV valve at valve cover AND where hose meets air intake hose.
Did the Seafoam carbon buster method
Checked all vacuum hoses
I've run the codes and nothing shows up.
Only thing I didn't do was replace the spark plugs, as I did that last year about 10K miles ago. Could it be the Seafoam treatment has ruined the plugs?
If I need to replace again, which type? Last time I used Champion 13 RS14YC6.
Thanks!
Old Nov 2, 2005 | 09:23 PM
96_4wdr's Avatar
96_4wdr
use a spray can of FI, TB or O2 sensor safe carb cleaner, spray around intake manifold base and plenum base, 4L's often vacuum leak like a sieve in these locations, rpm increase=leak found. solution=tighten bolts and respray to test for broken or missing gasket section.
also spray around MAF tube, TB and all vacuum hoses for leaks, cracked hose or cracked vacuum tree not easy to see.
is IAC actuating?, pull wire from IAC while idling, rpm decrease=PCM command reaching IAC.
also may be sticking EGR valve or other failure in EGR system.
i've used full can of Seafoam on several engines, no problemos
use Autolite or Motorcraft plugs only as per their replacement book. plugs usually show up as a high rpm, high load problem
check idle fuel pressure at fuel rail test point, >30psi and steady
iamoz
1983 - 2012 Ranger & B-Series
Jul 13, 2011 08:39 AM
93 mix 'n match
1997 - 2003 F150
Apr 24, 2011 02:02 PM
NemesisNJ
17
Jan 21, 2011 10:33 PM
Rockledge
May 27, 2006 06:20 PM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
