quick intake question
Old May 3, 2007 | 07:59 PM
1ole4d's Avatar
1ole4d
Would a stock 351W intake fit on a 302?
Old May 3, 2007 | 08:02 PM
havi's Avatar
havi
I'll have the Roast Duck
no, it's wider.
Old May 3, 2007 | 08:03 PM
flareside_thunder's Avatar
flareside_thunder
if you use the intake you HAVE to use the heads......yes it is wider...because of the deck heighths......
Old May 3, 2007 | 08:38 PM
1ole4d's Avatar
1ole4d
So if I swapped the 302 heads with the 351W heads the 351W intake would fit?
Old May 3, 2007 | 08:50 PM
flareside_thunder
correct, and you'd get slightly better flow = more torque
Old May 3, 2007 | 08:57 PM
1ole4d's Avatar
1ole4d
Hmmm...I never knew this. Wish I had known BEFORE I swapped the 302 in I have a stock 1969 351W and didn't know if the intake from that would fit the 302. If all I have to do is swap the heads....now you have my brain storming. lol thanks....
Old May 3, 2007 | 09:31 PM
EPNCSU2006's Avatar
EPNCSU2006
You can swap the 351 heads to the 302, but you still aren't going to be able to make the 351 manifold fit on the 302.
LxMan1's Avatar
LxMan1
Not true. There is little difference in the heads. The block is the reason that you can not use the 351W intake on a 302. The block is 1.3" taller and wider so the intake will not fit between the heads no matter which heads that you use.
The 69 heads may have a bit larger valves, but they are dimensionally the same on the outside.
So no, the 351W intake will not fit on a 302.
Old May 3, 2007 | 10:55 PM
78f-150Supercab's Avatar
78f-150Supercab
I feel the need to quote this to reinforce what LxMan1 said since someone said you can swap the intakes... you CANNOT swap the intakes. I don't know where he got his information, but hopefully now he knows better.<hints id="hah_hints"></hints>
Old May 4, 2007 | 02:08 AM
LxMan1's Avatar
LxMan1
You could bolt it to the valve covers
Old May 4, 2007 | 11:41 AM
1ole4d's Avatar
1ole4d
Thank you guys for clearing this up for me. Yes, I know better now. I didn't know if it was possible or not (didn't think so) so I figured I'd be safe and ask. I still haven't decided if I'm just going to find a 4v intake for the 302 or rebuild the 351W and drop that in. It's just a work/play truck I drive. Again, thanks for all your help!
Old May 4, 2007 | 12:04 PM
ken75ranger's Avatar
ken75ranger
Rebuilld the 351!!!!
Old May 4, 2007 | 12:11 PM
78f-150Supercab
lol, I was referring to flareside_thunder, who thought you could swap intakes, which you can't. I wasn't saying I hope you know better, I was saying I hope he knows better, and doesn't continue to pass on this misinformation. You were just asking a question. No problems there :-)
I would suggest you rebuild the 351 (as will everyone else, really). It'll have more torque and if you plan on doing any modifications, you'll get more power for cheaper out of the 351.
Old May 5, 2007 | 06:05 AM
HemiEater's Avatar
HemiEater
351W get it done........wish I had one when I built my 302.......
Old May 6, 2007 | 08:31 PM
flareside_thunder
I apologize for the misinformation.....but wouldn't you still be able toswap out the heads just have to use the sameintake?I shoulda thunk that....guessI didn't analyze my own post very well...especially when I even said sumthing about deck heighths.....whoops.
