Electric fuel pump re-wire
Old May 3, 2007 | 05:04 PM
yellow78ford's Avatar
yellow78ford
I bought my 78 f150 with an electric fuel pump used to fuel the engine. Only thing I don't like is how they wired it in. The fuel pump gets power in the acc. mode. I don't like this because sometimes I want to listen to the stereo when I'm outside of the truck but I can't because the pump powers up. Is there a place on the 78 I can wire it to for key-on only power or, should I just tap in an on/off switch which can possibly also be used in the event of an accident.
Old May 3, 2007 | 05:14 PM
beartracks's Avatar
beartracks
I would use a relay with power from the battery.Use ignition hot to energize the relay. Mount the relay under the hood. You could use a fuse tap on the fuse box for a circuit that's only hot with ignition on. Use a large wire for power to the pump.
Old May 3, 2007 | 05:19 PM
Mil1ion's Avatar
Mil1ion
Better yet is to hook it up to a oil pressure switch.
It doesn't power up until oil pressure reachs 5 lbs.
It will also shut the pump down when the engine stalls in case you're in a collision .........which a safety concern
Old May 3, 2007 | 06:02 PM
Mrcorey5's Avatar
Mrcorey5
Mr. mil1on,does that work with a gauge and /or idiot light sending unit?
Old May 3, 2007 | 07:01 PM
Southerngent35's Avatar
Southerngent35
My 77 came with an electric fuel pump rigged in to make the truck run. I dumped the electric and went back to the mechanical. Pain in the butt to change. I like things simpler. My 2 cents....
Old May 3, 2007 | 07:39 PM
Mil1ion's Avatar
Mil1ion
It works on its own.
All it is is a switch.. Pressure hits 5lbs..the circuit closes ....the pump starts up and as long as the PSI is above 0..it will keep running.
see second item listed.
http://www.marineengineparts.com/sho...ml/page81.html
Old May 3, 2007 | 07:42 PM
yellow78ford
The truck runs an aftermarket oil pressure unit. I notice the idiot light never lights up, even when just turning the key to the 'on' position so I'm not sure if it is still even functional. Where is the actual switch located?
Old May 3, 2007 | 07:49 PM
Mil1ion's Avatar
Mil1ion
It Tees into where the sending unit screws in.
I did this with a 80's Cadillac going from EFI to carb.
I interrupted the ground wire and tied into that for grounding out at 5 psi.
It worked like a charm.
to see an illustration scroll 1/2 way down this page.
Picture #3
http://www.allpar.com/history/mopar/electrical2.html
Old May 3, 2007 | 07:52 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
It is located on the back of the block just behind the intake manifold. If you have an aftermarket unit then it works off of oil pressure going to an analog gauge instead of electiral current.
Old May 3, 2007 | 07:59 PM
yellow78ford
Correct, that's how mine is. Any other suggestions on how to wire this up since the oil sending unit on mine is aftermarket and non-electrical current.
Old May 3, 2007 | 08:06 PM
Mil1ion's Avatar
Mil1ion
It T-s into the system with the SU and does not affect the oil pressure read out.
It is merely a automatic controlled switch by oil pressure from cranking the engine to start it.
Old May 4, 2007 | 09:30 AM
beartracks's Avatar
beartracks
For clarification, Dennis is talking about an aftermarket OP switch you add with a "T". If you turn over or whatever and the motor quits it will shut off the fuel pump. It's in addition to a relay and ignition on trigger.
Old May 4, 2007 | 12:54 PM
Mil1ion's Avatar
Mil1ion
It's my thought that it's a substitute for a Relay/trigger.
Old May 4, 2007 | 02:17 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Dont forget to mount the fuel pump lower than the gas tank, like on the frame and keep it as close to the tank as possible. Also its a really good idea to have some sort of bypass that recirculates back to the gas tank so the pump doesnt overheat while idling. Remember the pump pushes the same pressure no matter what the demand is from the carb. I have an electric pump on my 79. I added a fuel filter with 2 oulets. One goes to the carb and one goes to the recirc line on the evap system.
Old May 5, 2007 | 02:58 PM
m78's Avatar
m78
I thought i'd let you know what i just ran across on my 78 with an electric fuel pump that the original owner said he or had installed. The mechanical pump was leaking a little oil so i bought a plate to cover the hole after removing the m/pump. after doing that i noticed that the rubber fuel line next to the original steel line from the e/pump was run threw the m/pump.why i dont know.after rerouting and reconnecting the steel line i went to check where the e/pump was getting power and found that it wasnt enen hooked up.when i powered the e/pump i couldnt believe how loud it was.so i figured it would be easier to put a m/pump back on replace the steel line with s/s incase its rusted on the inside. this way i wont have to install a return line which would be a problem with two tanks because you would be transfuring fuel from one to the other. hope this was helpful.
fmc400
41
Sep 29, 2023 09:46 AM
78 Ford F150 460
17
Jun 24, 2012 11:31 PM
78f-150Supercab
Jun 24, 2007 01:44 AM
dover
13
Jun 20, 2004 12:53 PM
jaimalade
Mar 7, 2004 12:41 PM
