Max Temp? EGT, Oil, Diff
Old May 3, 2007 | 02:05 PM
USMC Diesel's Avatar
USMC Diesel
This Weekend I’m installing 3 new gages, Pyro pre Turbo, Differential 4:10 DRW, and Engine Oil.
Can anybody tell me what the normal operating temperatures are for these components, and what the max temperatures are?
Old May 3, 2007 | 02:35 PM
SpeedJunky's Avatar
SpeedJunky
The EGTs should've go in the 1200+ range for any longer than 30 seconds.
x 2 on the others...??
Old May 3, 2007 | 02:37 PM
tex25025's Avatar
tex25025
Pre turbo normal for just cruisin around 75 on the interstate I would see around 750-800, but then again I see a few hills and just in general terrain plays a part. As to max temp., I think most would say 1250, but that also depends on what type of exhause you have as well, aluminized exhausts you have to worry about heat scolding after 1250, while the others can tolerate higher temps, but all around 1250, rather it's for turbo/engine safety or maintain exhaust intregrity. I don't know about differential, I don't have that gauge. I do have a water temp gauge and I usually see around 200, I think 200-205 is roughly the normal, round 230 your pushing it(anyone want to chime in on that one?), I think that oil is going to be close to that, might be a little hotter, but it should be round there.
Old May 3, 2007 | 02:45 PM
USMC Diesel
In a few paychecks I’m looking at the T-409 stainless exhaust turbo back, it says it can handle up to 1450 but I don’t want to damage the turbo
Old May 3, 2007 | 04:02 PM
USMC Diesel
So far
Exhaust about 800 Normal 1250 Max
Oil 200 Normal 230 Max
Diff No info
Grinder Man
Oct 10, 2014 09:35 AM
jetact
Sep 14, 2010 09:30 PM
Technocrsr
Jun 6, 2007 08:27 PM
92Bronco-SA-TX
48
Aug 9, 2005 02:55 PM
92Bronco-SA-TX
1978 - 1996 Big Bronco
Aug 7, 2005 10:45 PM
