spark plug wires
Old May 3, 2007 | 07:06 AM
darascal's Avatar
darascal
spark plug wires
can you test spark plug wires? I went out at night and found no problem with them arcing last night put I am trying to track down this rough idle....also I have noticed that my engine has a valve tap for about the first 1-3 seconds should I worry?
Old May 3, 2007 | 07:27 AM
fordboy_52's Avatar
fordboy_52
you can check the resistance in the wires. put it on ohms setting and touch your leads together, it should peg the multi meter. than touch the two sides of the wires and get a resitance reading
Matt
Old May 3, 2007 | 07:49 AM
CMOS's Avatar
CMOS
Matt
What's the "acceptable" resistance range for "good" wires?
CMOS
Old May 3, 2007 | 08:01 AM
pawpaw's Avatar
pawpaw
Spark wire resistance should be about 1000 ohms per inch of length, 30,000 ohms max, no matter the length.
Old May 3, 2007 | 09:11 AM
CMOS's Avatar
CMOS
In reality if one of the wires is bad, you'd find it will have a significantly different resistance value than the "good" ones.
CMOS
Old May 3, 2007 | 09:22 AM
rubydist's Avatar
rubydist
Lifter rattle at startup is usually due to the lifters leaking down while the engine is off - the checkvalves usually leak due to varnish buildup. In my experience, you can often fix this by running synthetic oil for a couple of oil changes, especially if you select a synthetic oil like Delvac 1 that is rated for both gasoline and diesel engine use. (The synthetics, especially diesel rated ones, have more detergents.)
If the wire is bad, most likely the resistance will be more like infinity. However, the rough idle is not likely to be wire-related in my experience.
Old May 3, 2007 | 10:04 AM
aa4mi's Avatar
aa4mi
Just had a thought that might help. Many vehicles require a "pressure" gas cap and there is even a warning that fuel may spray out when opened.
I just replaced the gas cap on my old '83 for a few bucks. I don't know if it will help either me or you but at least I've eliminated one more item that may be forgotten.
Can't hurt but may help.
Carl
Old May 3, 2007 | 11:49 AM
CougarXR02's Avatar
CougarXR02
My last 3 Fords, a 97, and02, and a 1999 all got the rough Idle between 50-70,000 miles, and all needed new plug wires. I have been replacing them with Magnecor when I have the money. Jumped my gas mileage by 1-2 MPG on the Cougar. The B4000 I didnt have the cash yet to do, so it just got some cheapies.
In all cases, the wires fixed the problem for me.
Old May 3, 2007 | 11:40 PM
bleedinJDgreen's Avatar
bleedinJDgreen
oil & sticky valves
Maybe try running "Rislone" oil treatment every other oil change...in replace of a quart of oil. I have 109,000 on my ranger; and after 3-4,000 on every oil change. I usually run a quart once a year, but not in winter...the oil is still yellow/gold after every change. It's supposed to clean out the gunk in your engine & free the lifters/valves.
-I guess it's working cuz' from the looks of the oil, I have a clean engine.
Anybody else run Rislone, mystery oil, or sea-foam?
Last edited by bleedinJDgreen; May 3, 2007 at 11:42 PM. Reason: response to Rubydist
Old May 4, 2007 | 07:33 AM
pawpaw's Avatar
pawpaw
darascal, on your 3-4 second, start up engine tic, are you using something other than a Motorcraft oil filter?????
Has the "tic" been there since you bought your 3.0L with 170K on it, or did it come about AFTER you sprayed solvent into the intake, to tidy things up in there?????
Are you using the specified weight & API service grade, crank case lube????
Old May 4, 2007 | 08:25 AM
darascal's Avatar
darascal
I am using the fram oil filter the "tic" has been there since the day after I bought it aqnd to be honest I haven't gotten around to changing the oil yet so I can't be sure what oil is in it
Old May 4, 2007 | 08:39 AM
pawpaw's Avatar
pawpaw
OK, well I'd loose the Fram & use the specified Motorcraft filter, as it has the bypass valve setting properly specified & located for your engine & filters mounting position, same for the anti drainback valve & has the proper pressure drop across the filter media, so you don't get cold dry starts.
Also go with the specified viscosity & API grade crankcase lube, for your engine & the expected temperature range it'll see during the upcoming OCI.
Let us know how the "tic" responds.
Old May 4, 2007 | 09:34 AM
rubydist's Avatar
rubydist
Reading these will likely cure you from using Fram oil filters:
http://minimopar.knizefamily.net/oilfilterstudy.html
http://home.mindspring.com/~cewhite3nc/index.html
Old May 4, 2007 | 01:14 PM
aa4mi's Avatar
aa4mi
I just had my oil and filter changed at a shop about 2 weeks ago. This was the very first time and last that I will EVER do that.
It was just some generic thing and its sitting in my garbage can right now.
I bought a Motorcraft FL-1A for my 83 Ranger and replaced the oil per owners manual myself. Being retired I could not afford another change so I did it myself.
It starts quicker and runs smoother. Case closed.
Thanks for the other web sites; very interesting reading.
Carl
