Stacks
Old May 2, 2007 | 10:08 PM
61 uni's Avatar
61 uni
Stacks
How loud are in an extended cab truck? Who sells them?
Old May 5, 2007 | 12:16 AM
westtntrucker's Avatar
westtntrucker
With the windows rolled up, it not too bad. At freeway speeds pulling a heavy trailer, the resonance can get a little annoying at certain speeds. But hey, thats what a good stereo is for. There are several kits out there that come up through one hole in the passenger side of the bed, then tee off into dual upright stacks. This takes up alot of room in the front of the bed. My exhaust is split where the cat bolted to the exhaust pipe, then runs to each stack under the bed, leaving the front of the bed between the stacks open for use. The stacks are bolted to the bed with a custom adapter sort of like they use for stove pipes that go throught the roof. Then the pipes under the truck are routed to "slip" up into the stacks so the cab, bed, and frame can all move and twist with no binding. Also, when it rains the water will run out and down between the exhaust pipe and the stack. No ugly wet soot on your ride when you fire it up after rain, washing.
Stacks were purchased from a semi truck chrome shop 4 years ago. Local muffler shop bent the pipes under the truck to fit.
Old May 5, 2007 | 08:02 AM
tjbeggs's Avatar
tjbeggs
yep what he said. My stacks run thru one hole in the bed. They are quite loud with the windows down but with the windows up no too bad. they are a bit louder in the cab than my side pipe on my previous truck.
Old May 5, 2007 | 09:50 AM
Talyn's Avatar
Talyn
God, my truck is going to be so loud then. =*(
Big ole honkin 5 inch side pipes.....
I think the tough part will be getting he heat shield for around them, like they have on the semis.
Old May 5, 2007 | 10:39 AM
ozzy460's Avatar
ozzy460
i have 2, 5 in stacks single hole it the bed not loud at all but we'll see after this weekend , doing a 3 1/2 downpipe and convertor eliminator. cat was damn near plugged.
Old May 5, 2007 | 03:19 PM
westtntrucker
Go to a Kenworth truck dealer in your area. On the KW's, the mufflers are under the truck and the heat shields are for straight pipes. Should be easy to bolt on to your pipes.
Old May 5, 2007 | 09:34 PM
14psd's Avatar
14psd
MUFFLER???? you don't need no stinkin' muffler! Well unless your area requires them....ya know that legal issue thing. Go with out one if ya can. They sound great without a muffler...any way thats my $0.02.
Old May 6, 2007 | 12:49 AM
ech0sh4y's Avatar
ech0sh4y
Let me know if you find a good deal, I'm looking to do the same set up 2x 5" =D the muffler uh "feel off" and i lost my cat some where....
Old May 6, 2007 | 08:41 AM
westtntrucker
Was not talking about mufflers. I was talking about the Heat Shields that Talyn was wanting to put on. Was using KW trucks as a reference as opposed to other trucks that have the mufflers mounted verticly on the cab and the Heat Shields go around them, which, would be too big for those of us that do run straight pipes.
I also have deleted the muffs and kitty.
(just to clear things up)
Old May 6, 2007 | 03:51 PM
SDJTO's Avatar
SDJTO
Another thing to consider is the height of your stacks. My friend thought his stacks were too tall so he cut 7 in. off of them and the sound from the stacks is twice as loud.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
