Aftermarket Products
Sponsored by: Worksport
Train Air Horns
Old May 2, 2007 | 08:19 PM
Lariat#1's Avatar
Lariat#1
Talking Train Air Horns
Ok, Who here has these horns & do you like or Love them??? What brand & cost? Where did you mount them at, do you have any pictures??And last but not least howw do you have them wired??
Lariat#1
Old May 3, 2007 | 12:23 AM
angus's Avatar
angus
No train horns, just a big Grover air horn. It's mounted under the hood on the inner fender, with the bell right behind the horn opening next to the radiator. I tested it with a temporary air tank, but haven't finished doing a proper set-up for it. I ran tubing from an air horn valve in the cab, but that didn't seem to be a good idea: there's noticable delay while the air pressure builds up in the line. An electric valve near the horn may be a better idea, but first I'm going to try the next size up in tubing. I guess I could mount the valve next to the horn and use something like a bicycle brake cable to operate it from inside the cab.
Air tank will be a Euclid sausage tank from a big truck parts store.
The horn cost me about $15 at a swap meet, used. I've picked up a couple of NOS smaller Grover horns for around $30; maybe those will go on the opposite inner fender.
There's been a couple of times when some induhvidual has cut me off that I've deeply regretted not having this horn finished.
Old May 3, 2007 | 10:08 AM
airraid's Avatar
airraid
I have some horns that came off tugboats and ferries, and I've found ways to get them on both my trucks. I wired an A/B toggle switch so that the horn button on my steering wheel can be used with either the stock electric horns or the air horns. As you can see from the schematic below, my keyless entry system only has access to the electric horns--I did not want the air horns blowing when I locked the doors with my keychain fob!!!
Mount detail (my homemade brackets from 6061 aluminum):
My B4000 with same horns bolted to a "BackRack" brand rack and smaller 10 gallon compressor in the bed"
Larger 30 gallon compressor in the Sport Trac:
Horn selection switch console on my dash (also from 6061 aluminum bar):
My wiring schematic:
Old May 11, 2007 | 04:54 PM
FRETLESS6's Avatar
FRETLESS6
Wow! I found this post and thought, I have a great system for this guy. But now I see Airraid's system and I feel inadequate. I have a Viair compressor/tank with dual Kleinn trumpets running at about 160psi. I got the system from eBay stores for about $150. I mounted the horns on the frame directly behind my bumper and the compressor is on a bracket I fabricated from L-stock on the frame under the passenger side. I ran the switch into the cab with an air gauge I purchased from Vic-Hubbard. The whole set up cost less than $200. I pulled up in the parking lot of my office and blasted them to scare my co-workers and ended up making a guy upstairs almost mess his pants. He ran down, visibly shaken, to yell at me. But after I see Airraid's set up I may have to re work my system.
2000 F-250 SC SD 2WD
Old May 11, 2007 | 05:12 PM
sysman_rick's Avatar
sysman_rick
Post
You've got a orchestra. I just have 2 WOLO trumpets & a dinky compressor,but it beats the stock F-150 horns.
Old May 12, 2007 | 01:16 PM
wrobo23's Avatar
wrobo23
can i say holy sh** airraid?!?!?!? you literally have an assortment of airraid sirens on yer rig! are you like the paul revere in case of storms or something?!?
Old May 27, 2007 | 08:49 AM
bla1879's Avatar
bla1879
that is the most insane horn set up i have ever seen, how can you still have glass on your truck????, isnt it all gone after just one of those sounds? but i assume its not always in the truck, thatd be a touch impracticle, but i bet it gets the point across when someone cuts you off!!?? and lets any nearby ships know where you are as well
Old May 28, 2007 | 06:02 PM
WhiteEx's Avatar
WhiteEx
All the info you need including wiring diagrams: http://www.airhornsoftexas.com/
Old Jun 1, 2007 | 06:36 PM
nighthawk285's Avatar
nighthawk285
where do you get those tugboat and ferry horns there airraid? I've been looking for some boat foghorns, but I dont know where to look.
Old Jun 1, 2007 | 07:51 PM
airraid's Avatar
airraid
The smaller ones came to me via other collectors or eBay. Be prepared for sticker shock though, a cast bronze boat horn is not nearly as affordable as a cast aluminum train horn. Kahlenberg's horns, for example, have MSRPs up into the $30,000 range, and you have to fight rich yacht owners and commercial boat operators for the 2nd hand ones too.
Old Jun 1, 2007 | 08:37 PM
nighthawk285
hmmmmm, yeah, maybe i will keep looking then
Old Jun 1, 2007 | 10:29 PM
M. Kelly's Avatar
M. Kelly
horns
Another horn article.
https://www.ford-trucks.com/article/...k__Part_1.html
Old Jun 4, 2007 | 09:16 PM
78250crewcab4x4's Avatar
78250crewcab4x4
what is the legality on train horns in automobiles? we just got a set in at the shop where I work, you can really scare it out of people
Old Jun 5, 2007 | 12:07 AM
bla1879's Avatar
bla1879
theres prolly a limit on the decibil level, but big trucks have em i guess, hmm thats a good question 78250crewcab4x4
Old Jun 5, 2007 | 12:34 AM
airraid's Avatar
airraid
In nearly every state, what is OK or not is the discretion of the police. Here in MA, you can get fined for making any "unreasonably loud or harsh sound" with your vehicle, regardless of the source (horn, exhaust mods, backfiring, etc...).
