Steering system upgrade or not
Old May 2, 2007 | 09:16 AM
caseydudem's Avatar
caseydudem
Talking Steering system upgrade or not
My steering system is working pretty well, besides being a little looses, but I have heard some bad things about the system. The majority just say that the system is too weak. I'm luckey enough to have at least a solid front axle. I think that helps in the strenght department. My question is I have a new PS pump I'm wondering if I should really install it or try to look for an up grade? Thanks
Old May 2, 2007 | 02:11 PM
ForemanES's Avatar
ForemanES
The pump itself wont fix anything "loose". That sounds like a steering box problem. They can be easily adjusted to minimize the "loose" feeling. Just screw in that allan head screw untill you like it. Be careful, too much and it will bind on you, just go like 1/2 turn everytime.
Any upgrade for the steering system would be a costly hydrolic system.
Old May 2, 2007 | 02:46 PM
tjbeggs's Avatar
tjbeggs
the steering isn't weak in my eyes. its does struggle when huge tires are put on but thats true of all systems. ForemanES is correct that looseness is either a worn joint (tie rod end) or a steering gear that needs to be adjusted.
Old May 2, 2007 | 04:10 PM
powerstroked162's Avatar
powerstroked162
Took the words right outta my mouth. Better start checks some components
Cowboy Steve
Old May 2, 2007 | 10:36 PM
caseydudem's Avatar
caseydudem
Talking New
Well, the tie rods and the connecting rods are all new, so I guess that means it must be the box, and we you all say adjust the box, is that with the truck on the ground or raised up?
Old May 3, 2007 | 06:06 AM
Cuda_jim's Avatar
Cuda_jim
Check your ball joints too!
Here's a link for steering gear adjustment:
https://www.ford-trucks.com/forums/5...=steering+gear
Old May 3, 2007 | 10:09 AM
caseydudem's Avatar
caseydudem
Talking Okay
Well I will give it a try. I have heard that before. I guess I'm just afraid to mess it up and really break something. Thanks for the info.
Old May 3, 2007 | 12:06 PM
plowhand's Avatar
plowhand
Playing in the Dirt
caseydudem, it really is not hard to do. The old school way to do it is: with the truck off, sitting on the ground, mark on the gear box or make a reference of the slot in the steering gear adjuster (incase it moves), put a box end wrench on the steering gear adjuster lock nut, hold the steering gear adjuster with a long screwdriver, loosen the locknut. **If the steering gear adjuster moved, turn it back to the original setting.** Now screw the adjuster in 1/4 to 1/2 turn. Snug down the locknut **Do not tighten the locknut at this time**
Test drive the truck and check for slack in the steering and adjust the steering gear adjuster as needed. When you are satisfied, hold the steering gear adjuster and tighten down the lock nut. If you adjust the steering gear too tight, you'll know it because everytime you twitch your hand you will be all over the road. Hope this helps.
Old May 6, 2007 | 10:14 AM
pigfarmerdk1's Avatar
pigfarmerdk1
steering
Make sure your steering wheel doesnt have up and down movement, If it does your shart bushings are worn and will need to be replaced before you wear it out.
steve340
Nov 22, 2006 11:21 PM
beerguy5812
Nov 16, 2005 05:23 PM
gunmetal79
Nov 8, 2005 12:39 AM
BigMattXXL
Oil & Lubrication
Nov 24, 2002 01:22 AM
