1978 - 1996 Big Bronco
FUNKY COOLANT?
Old May 28, 2001 | 09:53 PM
351's Avatar
351
FUNKY COOLANT?
I'M WONDERING WHATS UP WITH MY COOLANT THIS IS THE SECOND TIME IN ABOUT 6 MONTHS AGO. I'VE FLUSHED IT BECAUSE THE COOLANT JUST LOOKED OFF. ITS THAT NEWER ORANGE STUFF. THE COLOR AND SMELL GOT ME THINKING ITS A HEAD GASKET BUT WHEN I LOOK AT THE DIPSTICK IT DOESN'T SHOW ANY SIGNS OF COOLANT. WHAT ELSE DO SOME OF YOU THINK OF THIS. I JUST FLUSHED IT AND REFILLED WITH JUST WATER TO BE ABLE TO SEE IT BETTER. THE EXPANSION TANK LOOKED REALLY BAD.
Old May 29, 2001 | 12:30 AM
Father_Flanagan's Avatar
Father_Flanagan
FUNKY COOLANT?
You cant mix the new coolant with the old green stuff. You have to do a serious flush before upgrading to the new generation of coolants. The old and the new mixed together causes corrosion. If there was even a little bit of ole green stuff left, they will react. There is a good chance your radiator is gunked up already...Good luck
Old May 29, 2001 | 01:30 AM
351's Avatar
351
FUNKY COOLANT?
thanks but i don't think that the problem i've been running the new stuff since it came out,for years. this is a new problem ,last 6 months, and even since then i've had a new radiator from a ford dealer installed
Old May 29, 2001 | 07:28 PM
AlM's Avatar
AlM
FUNKY COOLANT?
have you used stop leak recently?
have an auto tranny?
Old May 29, 2001 | 07:40 PM
RonBo's Avatar
RonBo
FUNKY COOLANT?
DO NOT use the orange coolant. It is called OAT (Organic Acid Treatment). It is not compatible with Ford vehicles. Some later model Ford products had orange as original coolant. It was found to be more harmful than helpful.Go back to using the green ethylene glycol that originally came with the vehicle. The OAT is ultra corrosive to the internals of your engine. 100% water is not a good idea either. While it has superior heat transfer characteristics, it does not have low freeze, or high boiling points.
Old May 30, 2001 | 12:34 PM
dryheat's Avatar
dryheat
FUNKY COOLANT?
PSU4ME
45
Nov 3, 2016 02:17 PM
Jaime74656
21
Sep 3, 2016 01:37 AM
olemoffat
Sep 22, 2013 12:47 AM
slenser
Mar 6, 2007 07:20 PM
vze2sgxa
Aug 7, 2006 07:08 PM
