Transmission problems F350
Old May 1, 2007 | 11:17 AM
bohne's Avatar
bohne
Unhappy Transmission problems F350
Hi,
I`m Joerg from Germany. I bought in the end of last year a Ford F350 Dually from 1989 with 7,3l Diesel engine, ATS Turbo and automatic transmission (E40D) . With the automatic transmission I have a big problem. It change the gears from 1 to 3 and in the overdrive, but it goes not down ( from 3 or 2 in 1) if you stop. It is only possible by manuell shifting with the gear selektor.
Do you have any idee?
I hope you can understand my bad english - soory I did my best .
Bye,
Bohne
Old May 1, 2007 | 06:07 PM
mhg's Avatar
mhg
english is ok, I understood
start by pulling the codes in the pcm
also being where you are easy access to
parts and testers will mean doing it the hard way
get a good digital volt ohm meter
check out www.fordfuelinjection.com
they have a wealth of info on pcm and e4od
Old Oct 10, 2007 | 04:20 PM
dontheroofer's Avatar
dontheroofer
i have 97 f350 diesel auto tranny started shifting hard and od lite is blinking can anybody tell me whats goin on ?
mode101
Jul 22, 2014 12:00 PM
Garyf100Bohn
Dec 5, 2011 12:16 AM
Eastfrisian
Nov 8, 2008 04:16 AM
bohne
Jul 15, 2007 09:35 AM
