Alignment for lifted crew
Old May 9, 2014 | 04:39 PM
tractoman's Avatar
tractoman
Gents,
I am trying to get my truck aligned and the caster is out of spec. One shop tried twice, without changing the ball joint camber/caster bushings which I asked them to do. My question is how much caster is too much? Max for my truck is 4.75 degrees and I am over 5 on both sides. It is a little work to go straight without constantly correcting. It has a 4" lift and 35's on it and all the front steering links and tie rods are new and it does have a drop pitman arm.
Old May 10, 2014 | 06:03 AM
fordman67's Avatar
fordman67
This does not add up. caster is what makes a vehhicle track on its own. u have over 5? On race cars most dial as much as can be had.it may steer a little harder at slow speed. caster on these straight axles is adjusted by the removable slugs in the upper ball joint.NOTHING else has anything to do with it.
are you sure you aren't -5* caaster needing +5*?
In an extreme situation if the camber slugs are not enough to correct the situation them a wedge shim between axle and spring though not supposed to be happening...that may be your only option.
i can not imagine not having enough adj within the axle though.a good alignment guy should be able to fix u up no prob unless your lift springs are maybe screwed up?
Old May 10, 2014 | 10:43 AM
tractoman's Avatar
tractoman
I currently have 5.4* and 5.2* caster. The spec is not more than 4.75*. The first shop did not replace the ball joint bushing and that is my concern. I would prefer it to be in spec and I am asking if too much caster is a problem? I am going to have another shop give me some input but thought I'd see how others with lifted trucks have their trucks set up. I think the first shop was too lazy to deal with the bushings.
Old May 10, 2014 | 10:48 AM
fordman67's Avatar
fordman67
More caster is GOOD if the camber and toe are good.i always want more positI've caster.it will make the truck track on the highway better!!!!!!
Old May 10, 2014 | 10:50 AM
fordman67's Avatar
fordman67
More positive caster will not cause adverse tire wear either.the split between the two isn't even too bad.id rock it like it is
jimjoebob99
13
Oct 26, 2010 09:38 AM
7278ford
1978 - 1996 Big Bronco
Oct 22, 2009 10:47 PM
jbirdsvt
Offroad & 4x4
Mar 6, 2007 08:23 PM
gatorpsd
Jan 11, 2006 05:20 PM
rhetor
May 13, 2004 07:45 PM
